Samco Silicone Hose Kit - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Aug 24th, 2007, 08:56 PM
WHITEY_'s Avatar
thewhitestuff
Local Time: 07:50 PM
United Kingdom Male View WHITEY_'s Cosmos Black & Body Color 1st Gen MINI One Profile View WHITEY_'s Classified Ads
Has anyone got this hose kit on their mini. If so could you post some pictures of how it looks in the engine compartment. Does anyone know how many tubes the kit consists of, will it replace all the tubing under the bonnet or just the main, easy to access ones? Thanks
Old Aug 24th, 2007, 10:15 PM
pardonator's Avatar
Send a message via Skype™ to pardonator
Local Time: 06:50 PM
United Kingdom Male View pardonator's Classified Ads
Supercoopers has it in blue, looks very nice. Seen it in the flesh, don't think there's a pic tho
Found that one...
Cooper S Hyper Blue - GTT/GRS/Speedline/KW
Old Aug 27th, 2007, 07:10 PM
HObzy's Avatar
United Kingdom View HObzy's Indi Blue & Black 1st Gen MINI Cooper S Profile
Hi, Ive got them. No photo yet sorry, will try to get one up. The induction hose is fairly easy to fit but the other are a major job as they are the coolant hoses. The fron tof the car needs to come off to get to 2 of them. The original clips are a PITA to get off to without a proper clip tool.
The kit doesnt replace all the tubes just the major ones - 6 if i recall correctly. Some will also need to be cut to fit correctly.
Old Aug 28th, 2007, 10:33 AM
Bhozar's Avatar
Overly excited!!
United Kingdom Male View Bhozar's Electric Blue & White 1st Gen MINI Cooper S Profile View Bhozar's Classified Ads
The samco kit I bought for my MCS was 4 hoses, which replaces the two small hoses that connect to the header tank, the two front hoses with one, and another one to the bottom of the rad to the right. None of the hoses needed to be cut.
The front two joined together with the bleed screw is one piece. The samco replacement has a screw in that bleeds the coolant. DO NOT USE A SPANNER ON IT. Make sure its only hand tight when you screw it back up or else you risk splitting the hose.
The SFS hose kit is 3 hoses. Two are for the front and uses the OEM bleed screw section, and the other peice is to the lower rad connection. As it doesnt replace the two smaller hoses form the header tank and doesnt use its own bleed screw the SFS kit is cheaper.
Cheapest place for the samco hoses is here: http://www.aldonauto.co.uk/shop/prod...hFor=&PT_ID=89
Old Aug 28th, 2007, 11:22 AM
MINI 2 Sponsor GT Tuning
United Kingdom View roland2003's Classified Ads
Bhozar is right. Samco ones have (in the past on the R5) had after a period of time a habit of leaking where the bleed union is bonded into the hose......I prefer the SFS design which retains the original bleed off.
Old Aug 28th, 2007, 11:25 AM
Aberdeen Al's Avatar
United Kingdom Male View Aberdeen Al's Classified Ads
Roland - Do you sell blue silicone hose that could be used for connecting to the GTT oil catch can?
Vroooom Vroooom
Old Aug 28th, 2007, 11:55 AM
Hi Al, Silicone hose (unless special flouro lined , which it rarely is..) is not suitable for oil . TBH your better off using multicarburant hose as supplied even though its black.
Best Regards Roland
Old Aug 29th, 2007, 08:15 AM
HObzy's Avatar
My apologies - I should have said that the INDUCTION hose, which is seperate from the kit, may need cutting depending on which induction kit you have fitted. With the JCW airbox, I needed to take off about 2 inches for a good fit. The coolant hoses all fitted spot on
Is that better
Old Aug 29th, 2007, 10:51 AM
Is that better
I second the above.......................I had to cut about 20mm off one end and 25mm off the other in order to keep the connector stub at the same height as the OEM induction hose..................I have the GTT CAI fitted to my car.
Vroooom Vroooom
Silicone Coolant Hose Kit? whokilledkaji First Generation MINI Tuning 0 Sep 28th, 2005 09:24 AM
samco hose kit Pepper'D First Generation MINI One D 1 Aug 5th, 2004 07:57 PM
