| Bypass valve modification I will be fitting the GTT oversize crank pulley and CAI hybrid filter to my 04 MCS 210 JCW. Can anybody please advise what the bypass valve modification means - what is done and how is it done and what are the benefits performance wise? Are special tools, parts or machining work required? |
| Can't find the post I saw originally but here's a snippet of Rolands wisdom "Hi Guys,From the factory every MCS weve ever worked on has a leaking bypass valve. Every car will benefit from having it adjusted properly. Not only will you gain more power,but better economy too. On full throttle any loss of boost is bad news. The power increase is probably around 5-8 bhp for most cars." Think of a hose pipe with a hole, going to lose pressure where you want it to come out. Photos are not from roland but another thread, link at bottom ![]() ![]() ![]() http://www.mini2.com/forum/engine-dr...libration.html Cooper S Hyper Blue - GTT/GRS/Speedline/KW |
| I not touched the VGS My bypass is done but it was by a MINI trained and also pretty experienced tech. Personally without that sort of mechanical (cooper S especially) experience I'd never touch anything as theres some other tricks to doing the bypass mod so the butterfly stays shut (however Roland is the man to talk to about getting one of his kits) |
| Wouldnt have a clue were to start myself without detailed instructions. Does Roland do this modification on it own? If so how much does he charge? Is this something that can be adjusted off the car or does it involve a trip to GTT? ![]() edited Ok other thread answered that, but where exactly do I get access to the valve? Wheres it situated? I'm suffering from alot of yo yo effect in 1st , 2nd and even 3rd. So would be keen to look at this. ![]() |
| When ever I can get the upload function to work I’ll show some photos of the bypass valve. Over the years there have been three different builds of the bypass valve. The early version had slot head screws on the butterfly plate and the later builds have T10 Torx head staked screws; the latest version has different casting features than the earlier part number. First loosen the butterfly plate screws and center the plate, tighten just enough to hold the plate, adjust the stop limiter set screw with and allen wrench till the plate almost occludes all light passing through, don’t completely close or binding may occur later, and tighten the butterfly fasteners. Some set screws have a very strong thread lock bond and may require a hit with a small flame tip torch. I’ve split some screws while loosening with the allen wrench so I now file the set screw contact point to adjust. The diaphragm return spring can also be replaced with a stiffer wind or the stock spring can be extended to make a more positive return. I don’t recommend the spring modification although many prefer it; be prepared for poor gas mileage if you go that route. Both the R&R and modification are a DIY, there’s no need to be intimidated by the prospect.. |
| Tags: bypass valve |
| modified bypass valve | Jaw_F430 | First Generation MINI Tuning | 4 | Sep 15th, 2007 08:28 PM |
| Bypass valve seems to be leaking????? | Loui | First Generation MINI Tuning | 0 | May 28th, 2007 09:26 PM |
| Bypass valve removal | Scoobystu | First Generation MINI Tuning | 9 | May 25th, 2006 12:56 PM |
| Ryephix bypass valve? | agile_moments | First Generation MINI Tuning | 6 | Aug 22nd, 2005 02:15 AM |
| Eaton bypass valve | FAT MINI | First Generation MINI Tuning | 4 | Oct 4th, 2004 01:01 PM |
