Does this belt need changing? - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Sep 15th, 2007, 05:41 PM
Damo's Avatar
Lights are on but...
Send a message via MSN to Damo
Local Time: 09:14 AM
United Kingdom Male View Damo's Solid Black & White 1st Gen MINI Cooper S Profile View Damo's Classified Ads
From this thread...
http://www.mini2.com/forum/engine-dr...rger-belt.html
...I get the impression it needs doing immediately?
Edit: this is on a car with a 17% Reduction Supercharger Pulley.
Old Sep 15th, 2007, 06:36 PM
supercoopers's Avatar
United Kingdom View supercoopers's Classified Ads
I would say yes. There is no spacer visible on the retainer tag! You won't be getting optimum performance with a stretched belt
Cheers,
Henry
Old Sep 15th, 2007, 07:08 PM
Damo's Avatar
What if I was to add it was a brand new belt 3 weeks ago when it was fitted and it has done 500 miles since.
Old Sep 16th, 2007, 07:03 AM
MINI 2 Sponsor GT Tuning
United Kingdom View roland2003's Classified Ads
Idealy with a new belt I like to see at least 13mm upto 20mm of available travel on the tensioner. Looks like the belts too long for the job. Full acceleration in first or second gear will result in running out of travel & belt slip.
We have a very special belt we took off a car last week.....I'll put a thread up next week ,that'll make you laugh.
Best Regards Roland GTT
Old Sep 16th, 2007, 10:30 AM
Damo's Avatar
Cheers for the info Roland Thought as much going to get it sorted.
Old Sep 16th, 2007, 04:45 PM
No problem stock crank pulley with -17% SC pulley works best with 1365mm belt...failing that a JCW 1374mm. The stock 1388mm is too long. We can supply the former if required.
Old Sep 16th, 2007, 05:15 PM
ScottyBoy's Avatar
Obsessive Car Cleaner OCC
Roland what size belt would a 15% pulley and a 2% crank pulley require?
Old Sep 16th, 2007, 05:18 PM
at a guess stock length.
Old Sep 16th, 2007, 05:39 PM
ScottyBoy's Avatar
Good as thats what ive got on and what i got advised to put on
Old Sep 16th, 2007, 07:00 PM
Damo's Avatar
This is odd. I'll bare it in mind if I can't sort it with the original supplier
The belt I had on as standard before the pulley change turned out to be the same size as a friend with a JCW car Not sure whether this was because I had a shorter belt (mine had done 40k his 30k) or whether his dealer never fitted the shorter belt in the first place!
But My tensioner had a good 5+mm of metal showing before the circle with my standard belt, and that was after 40k!
The new one I fitted with the Pulley was only marginaly smaller than the one that came off of the car. Can only assume the reason it was marginaly smaller was due to the old one probably having stretched after its 40,000 miles with the standard pulley, and the belt I have may in fact be for a standard car
Will see what happens.
Old Sep 16th, 2007, 10:33 PM
Damo's Avatar
Updated my earlier post to save duplication of a reply to the same thing twice.
Old Sep 18th, 2007, 06:56 PM
Damo's Avatar
Got chance to measure my stock belt tonight. It was 1380 on the exterior of the belt. As you can't measure it as a ring accuratly, I placed 3 markers around it flattened the individual sections and measured these and double checked so its its accurate. Baring in mind this belt has done 40,000 miles, it was certainly never a stick belt going off of Rolands figures, and thats assuming the outside is measured (as inside in theory should be a bit shorter).
So I can only assume my car had a JCW belt on it as after 40k its still nearer to the JCW belt size than the stock size.
Does anyone know if the belt size change due to something in the engine changing?
Old Sep 19th, 2007, 07:16 PM
Damo's Avatar
The belt currently fitted to my car is 1368mm, Consdering the little leeway its given can anyone give a knowledgable answer on what size would give it back its leeway, I'm thinking 1354-1358mm?
Old Sep 19th, 2007, 08:11 PM
Cooooooperslad's Avatar
United Kingdom View Cooooooperslad's Classified Ads
Roland how much do you charger (inc vat) for a belt change?
Follower of 1320autos + GTTuning
  #15 (permalink)
Old Oct 1st, 2007, 06:20 PM
Damo's Avatar
Just in case anyone was taking note of this thread.
MASSIVE Thanks to Lohen who offered to have a full butchers at the car to make sure everything was okay with the car.
They confirmed nothing unterward about the car itself and also that the belt I had removed was in fact a stock one not a JCW one. Not sure how I managed to measure it wrong
Anyway decided that would prefer that a shorter belt. Ended up with a 1353mm belt. Harder to fit but its done the job spot on. Looks like it did before the pulley was fitted
Changing Serpentine Belt - question clneal First Generation MINI Tuning 12 Jul 29th, 2011 06:25 PM
changing Belt andyferriby First Generation Faults & Fixes 6 Oct 3rd, 2010 05:55 PM
Which belt?? Cheech First Generation MINI Tuning 5 Mar 21st, 2007 09:24 AM
auxiliary drive belt / fan belt renewal sramdeen Maintenance & MINI Care 1 Jan 22nd, 2007 01:23 PM
