Supercharger belt size Hi all I will be fitting a -15% size s/c pulley and +2% size crank pulley next week and am a little confused about the best size of the serpentine belt to use. I've found this website which tells me that the stock size belt will be fine, however, I was under the impression that you should fit a smaller belt if you reduced the pulley size at all, even when fitting an over sized crank pulley. If someone could put my mind at ease it would be appreciated, I really don't want a belt slip on my first run after fitting! Cheers Mike |
| Cheers Richard, I think I will stick with the stock belt then. Good idea about the JCW belt, it may not be as short as the smaller aftermarket ones. I may still give GTT a call but you've given me the peace of mind I was after, thanks. Mike |
| Tags: belt, belt size, serpentine, supercharger |
| Supercharger Belt | KAS66 | First Generation MINI Tuning | 12 | Aug 8th, 2007 07:41 AM |
| Supercharger Belt Size | VMSETHAN | First Generation MINI Tuning | 2 | Apr 13th, 2007 03:32 PM |
| advice needed on supercharger belt | M444SSY | First Generation MINI Tuning | 3 | Oct 12th, 2005 10:24 PM |
| Supercharger Lube? Timing Belt? | Radar580 | First Generation MINI Cooper S | 2 | Jun 5th, 2004 12:17 AM |
| Supercharger Belt fitting | stu(pid) | First Generation MINI Tuning | 7 | Dec 10th, 2003 12:49 AM |
