| Defaintly was hot enough when testing? What petrol? |
| I'm booked in for my MOT tomorrow (1st one after fitting sports cat) so will report back. Not had any lights since fitting several months ago. GTT, GRS, Janspeed, JCW, OMP + various other bits - 232.6bhp, 191.2lbft on 1320's rolling road |
| Other causes include poor compression from poor seating of the valves in the head, incorrect cam timing, aftermarket mapping that does not put the car back in closed loop at idle and faulty upstream sensor.If you have had lots of backfiring this will ruin any cat (ask Ant FR about his Miltek cat !) Our car ran 550 injectors and flew through the mot with our turbo kit and GTT (Janspeed) cat... If the mapping is wrong and not going into closed loop the GTT AFPR may help but in closed loop (as it should be) the ecu should just adjust duration to achieve 14.7;1 AF ratio whatever injector size or pressure your running (within its correction limits). |
| Just got back from MOT, passed with flying colours - CO level = 0.03% at 2811rpm, HC = 3ppm ![]() MOT guy liked the exhaust noise (GTT Manifold + re-route pipe) GTT, GRS, Janspeed, JCW, OMP + various other bits - 232.6bhp, 191.2lbft on 1320's rolling road |
| Tags: gtt manifold, mot |
| GTT Manifold V JCW Motorsport Manifold | chrisflyer | First Generation MINI Tuning | 24 | Sep 26th, 2007 03:14 PM |
| MOT tomorrow...help | Cooperpot | General Discussion | 7 | Jun 12th, 2007 07:48 AM |
| MOT fail - rear discs too worn !! | mini2mad | First Generation Faults & Fixes | 5 | Sep 6th, 2004 09:14 AM |
| MOT tomorrow! - (update- passed!) | monsta | Maintenance & MINI Care | 16 | Aug 26th, 2004 04:28 PM |
