| Im running a 17% with stock size bottom pulley, and yes the gauge is calibrated!! Also running the GTT intercooler. Last time I went on a rolling road the guy at the place just made numbers up I think!! I do have a lot of logging equipment in the car so I have been able to set it up during road and track use. |
| Is that the efficiency of the charger or the complete setup you have tested? I have seen so many cars with boost leaks now that I have become numb to the "how much boost can the charger handle"! It all depends on you ability to cool the charged air? yes / no? |
| Also i'll throw another point in.... The smaller the pulley the more HP and Torque it requires to turn the SC so at what point are you increasing boost but not getting much from it due to the extra strain on the engine and charge temps? |
| The faster you spin the Eaton the more horsepower gets sapped First M45 Cooper S to run a 12 (12.96@105) On Nitrous 11.16@123 0-100 7.1991 ![]() http://www.1320MINI.co.uk |
| Have you done any testing though to show what the peak speed of the SC created the peak HP? I'm just really interested to know....... |
| yeah you have to over rev the M45 to make big boost. this takes the supercharger out of the efficencey range and you strat to heat the air more than actually move it. this is a problem with turbos, and why you will make more power from a larger turbo than a smaller one (you are moveing the same volume of air, just the boost form the bigger turbo is cooler and denser giving you more power). also this menas you have to run a bigger intercooler to get the temps back down. you dont just have to concider boost presure but airflow and the rpm the supercharger will be working at. is there any news on the OPCON (spell) twin screw 'charger??? thanks Chris. |
| Tags: teflon super charger |
| (JCW) stabiliser / sway bar / roll bar at One | B-R Mini | First Generation MINI One | 1 | Feb 22nd, 2006 05:31 PM |
| Alta Rally Light Bar or MINI Sport Light Lamp Bar | dinlo | First Generation MINI Exterior | 19 | Oct 18th, 2004 08:39 AM |
| Teflon coating - Waste of money? | Bananafishbones | Maintenance & MINI Care | 33 | May 31st, 2004 11:12 PM |
| Rear Sway Bar / Anti-roll Bar | DragonSean | First Generation MINI Suspension | 7 | Apr 20th, 2004 04:17 PM |
| Teflon Coating | Rory | Maintenance & MINI Care | 2 | Jan 27th, 2002 02:37 PM |
