| Hope it comes out alright |
| You're doing the right thing in going to an independant dyno before starting on the modding though That way, each time you add mods, you can go and do another a dyno run to see what the mods have done to your performance ![]() My Cooper is going on the rollers at the Surrey RR Dyno Day (see UK Events). She's had various mods fitted over the last 54k miles, but it currently standard except for some performance leads, so we'll see what happens there |
| Thanks for the replies. ![]() When I say health check, I don't suspect anything is wrong with it, wouldn't stick it on the dyno if there was. Plus it's only two years old, and has only covered 23k so everything should still be reasonably okay. My mate organises one each year, at the same place on the same dyno so should be a nice base point for measuring improvements. |
| We see between 125-130 stock and a best of 135 so far First M45 Cooper S to run a 12 (12.96@105) On Nitrous 11.16@123 0-100 7.1991 ![]() http://www.1320MINI.co.uk |
| You bring the piston upto top dead center (TDC) with all four valves shut and pump air into the cylinder, you then measure how much is leaking as a percentage. The lower the number the better. First M45 Cooper S to run a 12 (12.96@105) On Nitrous 11.16@123 0-100 7.1991 ![]() http://www.1320MINI.co.uk |
| We would also carry out a compression check at the same time, so an hour, which at the moment is £47. First M45 Cooper S to run a 12 (12.96@105) On Nitrous 11.16@123 0-100 7.1991 ![]() http://www.1320MINI.co.uk |
| Tags: bhp, cooper, road, rolling |
| 1320 Autos One / Cooper Rolling Road Project | Paul@1320 | First Generation MINI Tuning | 30 | Jul 18th, 2008 10:21 AM |
| Rolling Road | Ven0m | First Generation MINI Tuning | 32 | Feb 25th, 2008 03:11 PM |
| Rolling Road | AlexF2003 | First Generation Works | 14 | Oct 11th, 2007 02:29 PM |
| Just had my cooper on the rolling road | Dom | General Discussion | 22 | Apr 30th, 2002 11:20 AM |
