241.8 bhp & 210 ft lb @ Surrey Rolling Road - Page 5 - MINI Cooper Forum - MINI2 Mini Cooper Forums
  #61 (permalink)
Old Dec 2nd, 2007, 04:43 PM
Tüls's Avatar
450 BHP
Local Time: 02:03 PM
Quote: Originally Posted by Ant FR (original)
How do the new injectors get used fully without a change to the map. Surely they can only squirt what they are told to squirt ( that my layman term...) because even JCW cars that use the injectors have an uprated map on them.
It doesn't work exactly like that... the ECU is map is programmed with percentage and load... but not necessarily the injector size... even though the map is geared to the size of the factory injector... it's not sitting there "thinking" about the injector...
this really matters at idle... for instance i have 550s... and therefore I have to use a piggy back to trim back the fuel at low rpm... other wise I am shooting flames ever shift... which while that is neat.. it is not good for fuel consumption
so it works like this.. the injector is going to open X percent... but fuel pressure will then allow for more fuel to be pushed through due to the fact that once it's at 100% open... then the fuel pressure makes up what matters... if anything what this means is the percent that the injector is open is accually bigger than what is needed for a larger injector to deliver the same amount of fuel... so if anything you have MORE fuel than needed when you put larger injectors on...
the static fuel pressure in the mini is very high... compared to what I would run normally if I had a full after market fuel system... and the boosted fuel pressure is able to go equally high... allowing for the mini to very easily do things that would normally need to be addressed right away on other platforms...
so I know this isn't really the best explanation, you are correct though that rescaling for the injector size is the right way to do it... but that's mostly for drive ability and MPG than anything
JCW injectors are not big enough that it matters... and will allow for the extra fuel needed in most cases of modding since most people dont go too crazy...
  #62 (permalink)
Old Dec 2nd, 2007, 06:40 PM
Paul@1320's Avatar
MINI2 Sponsor
Local Time: 07:03 PM
Surely thats impossible using 550cc injectors on a Mini
First M45 Cooper S to run a 12 (12.96@105)
On Nitrous 11.16@123 0-100 7.1991
http://www.1320MINI.co.uk
  #63 (permalink)
Old Dec 2nd, 2007, 06:46 PM
Mini2 Sponsor & Tuner
Local Time: 10:03 AM
yes, UNpossible
you just need enough power to use them.....
  #64 (permalink)
Old Dec 2nd, 2007, 07:49 PM
Tüls's Avatar
450 BHP
ha ha I believe you have used mine infact!
Quote: Originally Posted by Revolution Mini Works (original)
yes, UNpossible
exactly
  #65 (permalink)
Old Dec 2nd, 2007, 08:02 PM
England
yes, UNpossible
i know what you mean
  #66 (permalink)
Old Dec 2nd, 2007, 08:25 PM
MINI-Morgan's Avatar
MINI Obsessed...
You obviously have memory loss from Saturday at the pub or was it all that banger racing effected your brain.
Damn... my brain hurts! I'll sleep on this and see if the answer comes to me......
Think all the petrol/exhaust fumes from all that banger racing and destruction derby has screwed my brain!
  #67 (permalink)
Old Dec 11th, 2007, 08:57 AM
Paul@1320's Avatar
MINI2 Sponsor
Forgot to say that we made more horsepower on our dyno with 330cc but I wouldn't advise a customer to do this, thats why we turned up at SRR with the 380cc in.
Cant wait to get a tune, hopefully this will be the next big leap for this combo.
  #68 (permalink)
Old Dec 11th, 2007, 09:15 AM
Local Time: 06:03 PM
England Male View Rigsey's Dark Silver & Black 1st Gen MINI Cooper S Profile View Rigsey's Classified Ads
Out of interest, why would you not recommend the 330's?
When is your tune due?
GTT, GRS, Janspeed, JCW, OMP + various other bits - 232.6bhp, 191.2lbft on 1320's rolling road
  #69 (permalink)
Old Dec 11th, 2007, 09:29 AM
Paul@1320's Avatar
MINI2 Sponsor
The a/f is to high, we'll be experimenting with Jan on what we can and cant do and coming up with the best combo for those particular cars.
We actually tried a stock cat last week and a one ball and a stock system.
Its so nice having the dyno so you can see what is happening.
Tags: , ,
Rolling Road Ven0m First Generation MINI Tuning 32 Feb 25th, 2008 03:11 PM
Rolling Road AlexF2003 First Generation Works 14 Oct 11th, 2007 02:29 PM
Went on the rolling road today!! GRSmotorsport First Generation MINI Tuning 3 Mar 31st, 2004 05:23 PM
Rolling Road James Haigh First Generation MINI Cooper S 3 Feb 28th, 2003 01:35 AM
Just had my cooper on the rolling road Dom General Discussion 22 Apr 30th, 2002 11:20 AM
