GRS or GTT?? - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Nov 25th, 2007, 12:15 PM
Local Time: 06:03 PM
United Kingdom View djwoody's Classified Ads
United-Kingdom GRS or GTT??
I'm having a problem deciding which Intercooler to get for my MCS!
Which one would you recommend out of the GRS and the GTT?
Chris
Old Nov 25th, 2007, 12:42 PM
Paul@1320's Avatar
MINI2 Sponsor
Local Time: 07:03 PM
GRS personally at the moment. £396 plus delivery
First M45 Cooper S to run a 12 (12.96@105)
On Nitrous 11.16@123 0-100 7.1991
http://www.1320MINI.co.uk
Old Nov 25th, 2007, 12:53 PM
BigShow's Avatar
MiniTorque*****
View BigShow's Classified Ads
I saw a back to back test of a MCS vs GRS on an RR and the temp diff was 10 degrees C in favour of the GRS... GRS all the way IMO.
Last edited by BigShow; Nov 25th, 2007 at 02:43 PM. Reason: I meant MCS not GTT Cooler
Old Nov 25th, 2007, 01:36 PM
Capsaisin's Avatar
cave capsicum
United Kingdom Male View Capsaisin's Chili Red & Black 1st Gen MINI Cooper S Profile
That's strange, because when Randy Webb tested the GRS intercooler, I believe he found a 10C difference in favour of the GRS compared to the standard S intercooler. More importantly he saw a 10 bhp increase in power with the GRS intercooler over the standard S intercooler.
What were the relative power gains that you saw between the GRS and the GTT intercoolers?
Old Nov 25th, 2007, 02:47 PM
Banned
England Male View lucachiarelli's Astro Black & Body Color 1st Gen MINI Cooper S Profile View lucachiarelli's Classified Ads
I have the gtt intercooler and am very happy with the looks and performance it has given me.
Old Nov 25th, 2007, 04:21 PM
sef's Avatar
sef
United Kingdom Male View sef's Hyper Blue & Black 1st Gen MINI Cooper S Profile View sef's Classified Ads
Any one fancy doing comparison tests? I have a GRS will be willing to run tests with someone that has the GTT... Could prove interesting... Could do a before on each car then swap I/C's over and run again to see what happens...
Old Nov 25th, 2007, 04:31 PM
sam_a156's Avatar
Flying Finn
Send a message via Skype™ to sam_a156
Local Time: 08:03 PM
Poland Male View sam_a156's Dark Silver & Black 1st Gen MINI Cooper S Profile View sam_a156's Classified Ads
Ouch, I can see another long and colorful thread building up
Old Nov 25th, 2007, 04:47 PM
Paul@1320's Avatar
MINI2 Sponsor
We can dyno the cars then do some in gear tests as well, recording boost IAT timing etc etc.
I was hoping Roland was going to post one up for evaluation.
Old Nov 25th, 2007, 04:50 PM
sef's Avatar
sef
Excellent... Hope he does... What do you think Roland?? Could be interesting... I volunteer my car as the testbed...
Old Nov 25th, 2007, 05:54 PM
Send a message via MSN to Fisher
Slovenia Male View Fisher's Electric Blue & White 1st Gen MINI Cooper S Profile
I am prefering a water to air system even it's more expensive.
Old Nov 25th, 2007, 06:00 PM
MINI 2 Sponsor GT Tuning
United Kingdom View roland2003's Classified Ads
Hi Guys, Ive already done the test (GRS v GTT) already on two different occasions. Once on a GTT220 (ish) spec car and once on my own. On average GTT is about 4 deg C cooler and achieves about 0.5-0.7 psi more boost. GTT is bigger (tube area around 15% more) that is the only reason why. We get extra size by providing a neat alloy plate that moves the coil back to give clearance where the HT leads are. Grahams is fine aswell ,its a bit cheaper as we're vat registered ,mind you outside the EU ours is just £399.
I hadnt intended putting this up ,but as someone mentioned it I've offered the results.
Oh we did some tests on a Forge one too.....you dont want to know how that faired (different car admittadly). We didnt compare to stock but tbf I think both GTT and GRS will outperform stock quite comfortably. I dont think RR's are going to be very reliable for testing ints tbh.
If the boost is up and charge temps are lower you can be almost guaranteed more power on the road. Its not rocket science or GTT badge that explain why it works better its effective area of the core. Both use quality core and both position well for the scoop. I use third gear with 4 or 5 WOT runs from about 3000rpm to 6800rpm watching the peak at end of each run, then taking average of the 5 runs. First run starts with charge air temp near as poss to ambient by driving off the throttle for a bit.
Best Regards Roland GTT
Old Nov 25th, 2007, 06:20 PM
sef's Avatar
sef
Guess that means no then...
Old Nov 25th, 2007, 06:34 PM
Paul@1320's Avatar
MINI2 Sponsor
You reckon, I thought it was quite a good offer, I'm sure there's someone out there who is willing to help out with the test.
Then we can have a;
pro GTT IC owner V pro GRS IC owner
Old Nov 25th, 2007, 06:38 PM
sef's Avatar
sef
Hope so... Just have to wait and see...
  #15 (permalink)
Old Nov 25th, 2007, 09:06 PM
LOBSTER!
Send a message via MSN to BRMCooper
GRS all the way baby
track and RR proven!
..::14.21@100.99MPH::..
15% Pulley, CAI, Mani, Back Box, GRS Intercooler
