| | LinkBack (2) | Thread Tools | Rate Thread |
| Difficult one to answer Karl, it just depends how anal you are When we're looking for 1/100ths a 1/10th is a lifetime ![]() How far do you think you can travel in a 1/10th of a sec at 100 + mph?? Answer 20 inches So if you're logging fo on the track and want to monitor what all 4 corners of the suspension and all 4 brakes are doing every 20 inches is a lot IMO. Again its how anal you want to be and how much you want to anaylise info, whether it makes you a better driver or your car handle and brake better with interperating the info provided to your advantage is another question ![]() The biggest problem you usually see is when people have a little info they always wished they had more. Some spend $10k to monitor a car for 7.8secs First M45 Cooper S to run a 12 (12.96@105) On Nitrous 11.16@123 0-100 7.1991 ![]() http://www.1320MINI.co.uk |
| So it can connect a wideband AFR controller and two more external sensors? Seems just what I need, I can then hook it up qith AFr, EGt and knock sensors...if only I knew about aftermarket knock sensors or how to connect to the stock one, that is... |
| We're an authorized Auterra dealer and I'll be happy to work with you guys if you want to put a group purchase together. Just keep the pricing discussion over on email and off the forums. Email link is available on our website in the left margin. DashDyno SPD |
LinkBacks (?)
LinkBack to this Thread: http://www.mini2.com/forum/first-generation-mini-tuning/151412-dashdyno-spd.html | ||||
| auterra dashdyno review | BoardReader | This thread | Refback | Dec 2nd, 2008 01:35 AM | |
| dashdyno | BoardReader | This thread | Refback | Nov 11th, 2008 12:49 AM | |
| Scangauge VS. DashDyno VS. G-Tech | brainycheddar | First Generation Interior & Ice | 0 | Dec 13th, 2007 06:29 PM |
