DashDyno SPD - MINI Cooper Forum - MINI2 Mini Cooper Forums
LinkBack (2) Thread Tools Rate Thread
Old Jan 13th, 2008, 01:51 AM
GTT 280's Avatar
The Power Cube
Local Time: 09:24 AM
United Kingdom View GTT 280's Classified Ads
Quote: Originally Posted by MINIAC (original)
Something a little pricier that has data logging capability:
DashDyno SPD
Ahhhhhhh... now we're talking !!!
+GPS HDOP
+GPS Satellites
+GPS Speed
+Analog In 1 - 6V
+Analog In 1 - 12V
+Analog In 1 - 24V
+Analog In 2 - 6V
+Analog In 2 - 12V
+Analog In 2 - 24V
+Analog In 3 - 6V
+Analog In 3 - 12V
+Analog In 3 - 24V
+Analog In 4 - 6V
+Analog In 4 - 12V
+Analog In 4 - 24V
+Digital In 1
Calculated Load Value
Engine Coolant Temp
Short Term Fuel Trim B1
Long Term Fuel Trim B1
Short Term Fuel Trim B2
Long Term Fuel Trim B2
Fuel Rail Pressure (gauge)
Intake Manifold Pressure
Engine RPM
Vehicle Speed
Ignition Timing Advance
Intake Air Temperature
Air Flow Rate From MAF
Absolute Throttle Position
O2 Sensor B1-S1
O2 Sensor B1-S2
O2 Sensor B1-S3
O2 Sensor B1-S4
O2 Sensor B2-S1
O2 Sensor B2-S2
O2 Sensor B2-S3
O2 Sensor B2-S4
Time Since Engine Start
Distance Traveled While MIL On
Fuel Rail Pressure Rel Manifold
Fuel Rail Pressure
O2 Sensor B1-S1 Wide Range V
O2 Sensor B1-S2 Wide Range V
O2 Sensor B1-S3 Wide Range V
O2 Sensor B1-S4 Wide Range V
O2 Sensor B2-S1 Wide Range V
O2 Sensor B2-S2 Wide Range V
O2 Sensor B2-S3 Wide Range V
O2 Sensor B2-S4 Wide Range V
Commanded EGR
EGR Error
Commanded Evaporative Purge
Fuel Level Input
Warm-ups Since DTCs Cleared
Distance Since DTCs Cleared
Evap System Vapor Pressure
Barometric Pressure
O2 Sensor B1-S1 Wide Range mA
O2 Sensor B1-S2 Wide Range mA
O2 Sensor B1-S3 Wide Range mA
O2 Sensor B1-S4 Wide Range mA
O2 Sensor B2-S1 Wide Range mA
O2 Sensor B2-S2 Wide Range mA
O2 Sensor B2-S3 Wide Range mA
O2 Sensor B2-S4 Wide Range mA
Ambient Air Temperature Absolute Throttle Position B
Absolute Throttle Position C
Absolute Throttle Position D
Absolute Throttle Position E
Absolute Throttle Position F
Commanded Throttle Actuator
Minutes Run with MIL ON
Time Since DTCs Cleared
Catalyst Temp Bank 1 - Sensor 1
Catalyst Temp Bank 2 - Sensor 1
Catalyst Temp Bank 1 - Sensor 2
Catalyst Temp Bank 2 - Sensor 2
Control Module Voltage
Absolute Load Value
Commanded Equivalence Ratio
Relative Throttle Position
*Short Term Fuel Trim B3
*Long Term Fuel Trim B3
*Short Term Fuel Trim B4
*Long Term Fuel Trim B4
*Short Term Fuel Trim B1-S1
*Short Term Fuel Trim B1-S2
*Short Term Fuel Trim B1-S3
*Short Term Fuel Trim B1-S4
*Short Term Fuel Trim B2-S1
*Short Term Fuel Trim B2-S2
*Short Term Fuel Trim B2-S3
*Short Term Fuel Trim B2-S4
*Equivalence Ratio B1-S1
*Equivalence Ratio B1-S2
*Equivalence Ratio B1-S3
*Equivalence Ratio B1-S4
*Equivalence Ratio B2-S1
*Equivalence Ratio B2-S2
*Equivalence Ratio B2-S3
*Equivalence Ratio B2-S4
*Equivalence Ratio B1-S1 2
*Equivalence Ratio B1-S2 2
*Equivalence Ratio B1-S3 2
*Equivalence Ratio B1-S4 2
*Equivalence Ratio B2-S1 2
*Equivalence Ratio B2-S2 2
*Equivalence Ratio B2-S3 2
*Equivalence Ratio B2-S4 2
*Instant Economy
*Average Economy
*Fuel Used
*Distance Traveled
*Air Fuel Ratio
*Air Fuel Ratio B1-S1
*Air Fuel Ratio B1-S2
*Air Fuel Ratio B1-S3
*Air Fuel Ratio B1-S4
*Air Fuel Ratio B2-S1
*Air Fuel Ratio B2-S2
*Air Fuel Ratio B2-S3
*Air Fuel Ratio B2-S4
*Air Fuel Ratio B1-S1 2
*Air Fuel Ratio B1-S2 2
*Air Fuel Ratio B1-S3 2
*Air Fuel Ratio B1-S4 2
*Air Fuel Ratio B2-S1 2
*Air Fuel Ratio B2-S2 2
*Air Fuel Ratio B2-S3 2
*Air Fuel Ratio B2-S4 2
*Boost Pressure
Last edited by MINIAC; Jan 13th, 2008 at 03:34 PM. Reason: Merge consecutive posts
Old Jan 13th, 2008, 07:44 AM
Local Time: 08:24 AM
I find the open and closed loop data very useful when reading the co2
Old Jan 13th, 2008, 08:26 AM
alski's Avatar
dyno-mite, might not....
England Male View alski's Classified Ads
DashDyno SPD
also measures hp and torque.....
and costs about the same as 3 rolling road sessions ...
all this when on the road, real data, no fans etc ....
am i missing somthing here....
Home > Products > DashDyno > DashDyno SPD ProPack
DashDyno SPD™ combines a scan tool, performance meter and data logger into one, easy-to-use instrument for the automotive enthusiast.
The dynamometer measures horsepower/torque and acceleration times. Results are graphically displayed with zoom and scroll.
The data logger records data from the vehicle diagnostic port, analog inputs, a digital input, and an external GPS or wideband O2 sensor. Recorded data may be viewed directly on DashDyno or using a PC with the included Dyno-Scan for Windows software.
Read and clear the dashboard Check Engine light. Access to thousands of generic and enhanced diagnostic trouble code definitions displayed directly on screen.
Learn More About DashDyno » Price and Order button below »
IN STOCK, usually ships in 1 - 2 business days. Press the Order button below to purchase.Package Contents
The A-501 DashDyno SPD ProPack kit includes:
  • DashDyno SPD
  • DashDyno SPD Software CD ROM (S-102)
  • Dyno-Scan for Windows software
  • OBD II Cable (O-102)
  • DashDyno Serial GPS Cable (C-160)
  • USB Cable (C-151)
  • 128MB SD Card
  • Quick Release Suction Cup Windshield Mount (C-200)
  • Female Quick Release Mounting Screws
  • AC Adapter (C-201)
  • Cable Tie
  • Quick Start Guide
  • Electronic User Manual
Key Features
Key Features
All 1996 and later vehicles supported, including American, Asian, and European
Easy installation - no hard wiring required
Includes Dyno-Scan for Windows software for PC-based diagnostics Can be dash mounted or handheld
Quick release windshield mount option
Powerful 32-bit microprocessor
Backlit high-contrast LCD display with temperature contrast compensation
133 selectable parameters and simultaneously record up to 16
Record GPS data using an external GPS receiver
View GPS data within Google Earth
Powered from an OBD II cable or A/C adapter
Measures Horsepower and Torque corrected per SAE 1349
0-60mph, 1/8 and 1/4 mile, and top speed
Trip computer with instant and average fuel economy
SD / MMC card slot for recording data
Playback recorded data and use fast forward/reverse for quick navigation
Three user programmable alarm lights
Record / play and keyboard shift key indicator lights
8 button backlit keypad with secondary functions
USB port for connection to a PC
Two expansion ports for optional accessories and sensor logging
Four external analog inputs, a digital input, a digital output, and a serial port
Analog input range select (0-6V, 0-12V and 0-24V)
2-channel digital oscilloscope mode
Customizable sensor conversion formulas
Software wizards offer step by step guidance
Read and clear diagnostic trouble codes
Enhanced and generic code definitions displayed on screen
Turn off Check Engine or Service Engine Soon light
Line graphs, bar graphs, meters and gauges
J1850 (VPW, PWM), ISO 9141, ISO 14320 (KWP), and ISO 15765 (CAN bus) protocols
CAN bus 6x mode reads six sensors at once from the vehicle
carefree
Old Jan 13th, 2008, 10:31 AM
NeuroBeaker's Avatar
PowerSteeringPumpActivist
Scotland Male View NeuroBeaker's Indi Blue & Body Color 1st Gen MINI One Profile
I quite like the look of the version that runs on the Palm OS:
Dyno-Scan for Palm
Very swish.
NeuroBeaker - Proud owner of Zeus (a 'modestly modified' 2004 MINI ONE).
Helpful Links: [1st Gen. Power Steering Pump (PSP) Failure Guide] [1st Gen. PSP Repair] [Thread Titles] [Adverts Fix]
Old Jan 13th, 2008, 05:31 PM
MINI-Morgan's Avatar
MINI Obsessed...
Nice long list but surely that is the maximum available and not what you will get on the MINI?
Old Jan 13th, 2008, 08:30 PM
As with all OBD devices its only as good as the ecu comms.
even if it can scan every second, it does not mean that all the inputs are logged at the same time, and when looking at engines at 6000 rpm a lot can happen in 0.5 of a second!
Also you are reading the cars sensors, how do you know they are correct? eg, if you map sensor is on the way out or reading in accurate how will you know?
The only proper way to datalog is via direct calibrated sensors.
But it get expensive, but its like anything that is used to measure!
Old Jan 13th, 2008, 08:39 PM
Paul@1320's Avatar
MINI2 Sponsor
Before ordering just check that it will work with the Mini, most unfortunatley cant.
First M45 Cooper S to run a 12 (12.96@105)
On Nitrous 11.16@123 0-100 7.1991
http://www.1320MINI.co.uk
Old Jan 13th, 2008, 09:14 PM
Loui's Avatar
230whp an counting
England Male View Loui's Solid Black & Body Color 1st Gen MINI Cooper S Profile View Loui's Classified Ads
I prefer the idea you had earlier tbh
Old Jan 20th, 2008, 07:58 AM
GTT 280's Avatar
The Power Cube
has anybody ever dealt with DashDyno - i sent them an email over a week ago now and heard nothing already.
Cheers,
K.
Old Feb 3rd, 2008, 04:57 PM
Jaw_F430's Avatar
M3 CSL
United Kingdom Male View Jaw_F430's Solid Black & Body Color 1st Gen MINI Cooper S Profile View Jaw_F430's Classified Ads
Has anyone bought one of these?
Old Feb 3rd, 2008, 09:04 PM
GTT 280's Avatar
The Power Cube
not yet, i got no reply from my "is it MINI compatible?" email.
But if it is, then i'll be getting one pronto, and also 4 specific and highly calibrated sensors to cover the 4 most important variables available to the driver to monitor engine safety. The results on a OBDii are only as good as the sensors that provide that data.
Cheers,
K.
Old Feb 4th, 2008, 12:33 PM
Jaw_F430's Avatar
M3 CSL
Cheers,
K.
Do you think if a few people wanted one we could get a bit of discount for ordering a few?
Regards
James
Old Feb 4th, 2008, 01:02 PM
GTT 280's Avatar
The Power Cube
not sure, i can find out. i will email them again - lazy dogs !!!
Old Feb 4th, 2008, 01:09 PM
GTT 280's Avatar
The Power Cube
If you live within Europe and the UK, EOBD (European On-Board Diagnostics) is required. The Dyno-Scan works on EOBD vehicles.
  #15 (permalink)
Old Feb 4th, 2008, 01:12 PM
GTT 280's Avatar
The Power Cube
no answer via email... if anyone wants to call the US then please do so....
E-mail technical support at: support@auterraweb.com. Phone technical support at 760-739-8506 x103.
LinkBacks (?)
LinkBack to this Thread: http://www.mini2.com/forum/first-generation-mini-tuning/151412-dashdyno-spd.html
Posted By For Type Date
auterra dashdyno review | BoardReader This thread Refback Dec 2nd, 2008 12:35 AM
dashdyno | BoardReader This thread Refback Nov 10th, 2008 11:49 PM
Scangauge VS. DashDyno VS. G-Tech brainycheddar First Generation Interior & Ice 0 Dec 13th, 2007 05:29 PM
