| Bypass valve Hi All Got some issues with JCW (see here, think I posted in wrong forum...http://www.mini2.com/forum/faults-fi...per-works.html) Anyway I think I've got a problem with the Spring on the BPV as my car feels very slow at the minute like it's way down on power/torque. All of a sudden yesterday it seemed to get better, but again today it's back. I think the Spring is sticking, as when I touch it and pull it back with my finger, it doesn't go back all the way and you have to push it the rest of the way. See the picture, can someone tell me if that is the BPV Spring? Thanks alot Gav |
| Out of interest did you find out how much the valve is on its own?? Glad you're all sorted Suprising how often it isnt people getting useto the car but more the car actually getting slower. |
| Thanks guys! Doesnt look to be massively expensive then. Going to test the mod to make it more responsive...... |
| I just broke the grub screw on my bypass valve (it had been stuck in with loctite). I decided to drill out the screw, and retap it. Bad idea. Ive now completely snapped the bit of metal. Im contemplating getting a Detroit tuned one? If they will send it over, i reckon it will be about $160, which is about £80. Anyone know if any of the UK companys offer a similar product? I need a BPV asap, or my car will stay in the garage Superchargedddddddddd! |
| I have a DT bypass valve in right now and I'll post my thoughts on it. First, the response is a lot quicker and the car is definitely getting all the boost. That is the great part of the valve. The downside to the valve is that at standard use of the throttle the car seems a bit choppy. This is due to the on or off nature of the valve with the heavier spring. I think that nicely adjusted OEM valve will provide a better ride for the daily driver. |
| Don't know on this one. There have been three versions of them according to RealOEM.... Here is the latest part number. 11617568423 RealOEM.COM * BMW R53 Cooper S CHARGE-AIR COOLING |
| Tags: bpv, bypass valve |
| bypass valve question | Babes | First Generation MINI Tuning | 25 | Jan 31st, 2008 04:32 PM |
| modified bypass valve | Jaw_F430 | First Generation MINI Tuning | 4 | Sep 15th, 2007 08:28 PM |
| Bypass valve modification | BlueMax | First Generation MINI Tuning | 18 | Sep 4th, 2007 03:01 PM |
| optimised bypass valve | miniwurks | First Generation MINI Cooper S | 8 | Feb 15th, 2007 09:04 AM |
| GTT 210 'optimised bypass valve' | venox22 | First Generation MINI Tuning | 6 | Aug 24th, 2005 05:29 PM |
