Scangauge XGauge Boost - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Feb 29th, 2008, 08:20 PM
MINIAC's Avatar
Canned
Local Time: 03:30 AM
There's no longer any need to "do the math" in using MAP readings to determine boost as someone has come up with an XGauge to do it:
  • To start, from the HOME screen use MORE>MORE>MORE>XGAUGE
  • Then in the top right select the number of the XGauge memory you want to use (0 to 24)
  • Next press <EDIT which takes you to the TXD screen
  • Using the buttons next to + and - to select characters and the -> in the top right to move to the next character:
    • Enter 686AF1010B on the TXD screen and press OK>
    • Enter 0441850B0000 on the RXF screen and press OK>
    • Enter 2808 on the RXD screen and press OK>
    • Enter 00910064#### on the MTH screen and press OK>
      Code:
      ####    PSI
      FF8A    11.8
      FF89    11.9
      FF88    12.0
      FF87    12.1
      FF86    12.2
      FF85    12.3
      FF84    12.4
      FF83    12.5
      FF82    12.6
      FF81    12.7
      FF80    12.8
      FF7F    12.9
      FF7E    13.0
      FF7D    13.1
      FF7C    13.2
      FF7B    13.3
      FF7A    13.4
      FF79    13.5
      FF78    13.6
      FF77    13.7
      FF76    13.8
      FF75    13.9
      FF74    14.0
      FF73    14.1
      FF72    14.2
      FF71    14.3
      FF70    14.4
      FF6F    14.5
      FF6E    14.6
      FF6D    14.7
      FF6C    14.8
      FF6B    14.9
      FF6A    15.0
      NOTE: Atmospheric Pressure: 6,000 ft above to 500 ft below sea level
    • Enter "BST" or whatever name (3 characters max) you would like for the XGauge and press OK>
  • Lastly press SAVE>
The MAP [engine off] reading on my Scangauge was 14.5. Using "FF6F" for the MTH screen value resulted in a BST reading of -0.2 so I had to use "FF71" to make it read 0.0.
The Following 4 Users Say Thank You to MINIAC For This Useful Post:
Old Mar 13th, 2008, 10:45 PM
BigShow's Avatar
MiniTorque*****
Local Time: 11:30 AM
View BigShow's Classified Ads
Just done it, my MAP read 14.3 when done
Old May 2nd, 2008, 06:37 AM
Aberdeen Al's Avatar
Local Time: 12:30 PM
United Kingdom Male View Aberdeen Al's Classified Ads
Snap!
Vroooom Vroooom
Old May 2nd, 2008, 09:10 AM
Will do mine tonight, cheers for this
Old May 2nd, 2008, 12:03 PM
My Scangauge was showing 24.3 PSI boost (prior to removing the 14.2 / .3) so I reckon I'm low but I cannot see why as I'm getting no leak unless of course it's due to my "piped" up but not electronically connected boost gauge
Vroooom Vroooom
Utilizing Scangauge Readings MINIAC First Generation MINI Tuning 7 Oct 21st, 2008 08:59 AM
Scangauge 2 Rigsey First Generation MINI Tuning 107 May 7th, 2008 09:43 AM
Scangauge VS. DashDyno VS. G-Tech brainycheddar First Generation Interior & Ice 0 Dec 13th, 2007 06:29 PM
Boost Cass --> Boost CD upgrade (HK fitted) john_o First Generation Interior & Ice 0 Jan 10th, 2005 08:36 PM
