Torque more important than BHP? - Page 3 - MINI Cooper Forum - MINI2 Mini Cooper Forums
  #31 (permalink)
Old Mar 5th, 2008, 10:38 PM
Mini2 Sponsor & Tuner
Local Time: 10:05 AM
Quote: Originally Posted by Damo (original)
Well I currently have a Play MINI that is a lot louder than stock, and I've got used to it at speed on the motorway, but if I was to get anything to loud on the motorway my Mrs would kill me
The full miltek system is louder than mine under power but sounds quieter than mine when cruising. But then Graham's car is geared higher as mine is a facelift his isn't.
to fool the Mrs... slightly crack both windows... it's amazing how much quieter it is
  #32 (permalink)
Old Mar 9th, 2008, 11:23 PM
Loui's Avatar
230whp an counting
Local Time: 06:05 PM
England Male View Loui's Solid Black & Body Color 1st Gen MINI Cooper S Profile View Loui's Classified Ads
Quote: Originally Posted by Charger_Pete (original)
Hi guys
Please can I add the following that may clarify the power/torque debate:
Power [kW] = (2 * pi * (engine speed [rpm]/60) * Torque [Nm])/1000
As you can see, engine power increases in proportion with engine speed and torque. So, it is very desirable to tune the fattest torque curve you can across the whole engine speed range in order to satisfy mid-range driveability and peak power requirements. It can be said that Power is, in effect, the rate of change of work done [i.e. torque] from the above equation.
A tuners aim is to maximise the engine torque at peak engine speed by maximising the airflow through the engine and achieving the largest (safe) cylinder pressure the combustion system can withstand.
So, in answer to your question "is torque more important than bhp?", torque is power therefore is equally important and relevant.
Pete
[a.k.a GEEK boy]
You geek but a very valid point
Tags: , ,
Which is more important... Drillslinger General Discussion 14 Dec 29th, 2005 06:22 AM
More important - torque or bhp? Pauly General Discussion 4 Apr 9th, 2004 07:31 PM
Important! NE1 know G8 BAD!? Mr.Chrome Dealership Feedback 28 Nov 15th, 2002 07:38 AM
