'02 One - timing belt/chain ? life ? - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Mar 11th, 2008, 12:05 AM
Local Time: 11:17 PM
Engine is W10B16A - is the timing/cam a belt or chain ? what is the service requirement ? I think that it is a chain and the belt is only for water pump / alternator drive etc. but I am not sure if it varies between engine ?
Old Mar 11th, 2008, 11:49 AM
Local Time: 10:17 PM
United Kingdom View paul_c's Classified Ads
i think you are refering to the poly-v belt. This is changed at Service Inspection 2, which should be your 4th service. Mine is coming up ('02 cooper) in 2,000miles so will be at 43,000 miles .
"i'm f.i.n.e" ....
Old Jul 5th, 2008, 01:50 PM
Someone else on this forum says 120000 miles?
Old Jul 5th, 2008, 02:15 PM
MINI-Morgan's Avatar
MINI Obsessed...
Its a chain and I thought it was for life of the engine.
Old Jul 5th, 2008, 02:21 PM
James@fomsport's Avatar
Scotland Male View James@fomsport's Classified Ads
the timing is chain cam, the crank belt drives the alternator and water pump and air con on the cooper and those + the s charger on the s s should be swapped every year not sure on the one / cooper
Tags: , , ,
Cam Chain or Cam Belt on Mini One D dh2310 First Generation MINI Tuning 1 Oct 24th, 2007 02:44 PM
Chain or belt? Ramon First Generation MINI Tuning 2 Aug 1st, 2007 09:05 PM
WHEN to change timing belt SPClark First Generation MINI Cooper S 3 Mar 18th, 2005 03:58 PM
Timing Belt tools113 General Discussion 10 Jan 27th, 2005 05:49 PM
is there a timing belt? KAMAKAZI First Generation MINI Cooper S 6 Aug 25th, 2004 08:44 AM
