| | LinkBack (3) | Thread Tools | Rate Thread |
| Apparently its at its best on an automatic. Regarding the warning lights, the instructions with my generation 2 sprint booster state to leave the car door open for 5 mins before fitting to aviod warning lights. Fitting mine tomorrow... can't bloody wait! |
| Fitted the sprint booster at the weekend. It certainly makes the car feel more lively. It has 3 settings off, green and red mode. Green mode is not really a massive difference to be honest but red is. The car just feels more eager and ready to respond quicker. When you switch it off it actually feels a bit sluggish! Fitting was easy. Just depress the retaining clip on the left hand side of the pedal and slide the whole unit off. Attach the cable and slide the pedal back into place. Takes about 5-10 mins. However, I did get the engine management light on afterwards. But it was just a case of disconnecting the battery for 10 mins to clear it. Found a great place to mount the controller too. On my mini there was a blanking switch plate to the right hand side of the steering wheel in the lower panel. I drilled out the bottom of the blanking plate to allow for the cable to tuck in and super glued the controller to the blanking plate and re-inserted it. The controller is almost exactly the same size as the blanking plate so it looks almost factory fitted and you cant see any cable. Its in a good location for use too. If you share a the car with someone else its good to able to turn it off too. My girlfriend prefers it off. People say that it takes time to get used to but having only had my mini for a few weeks I just found that it made it more normal. To me the mini fly-by-wire throttle has a serious delay in standard form. I would say that the sprint controller is a good mod but it is fairly expensive i suppose. If you compare it to getting a rechip or a bluefin then obviously you can get better bang for your buck. Am guessing it would work pretty well in conjuction with a rechip. Thats what I am doing next.... Damn, I think i am catching the bug. |
| Yes, will do. Might not be able to get a chance to take a pic in daylight till the weekend though. Its great because it totally hides the cable and also the only part that you need to modify is the switch blanking plate and they are easy to obtain if you ever remove the booster or sell the car. No harm dont to the dash itself. |
| Hello All Other half has a R50 Cooper Auto/CVT and wanted to know if this mod would be worthwhile. Been thinking of a map to make it more drivable but £££ for a 10odd bhp gain doesn't seem worthwhile. Any CVT owners running one? |
| Tags: great throttle respose |
LinkBacks (?)
LinkBack to this Thread: http://www.mini2.com/forum/first-generation-mini-tuning/154186-sprint-booster.html | ||||
| MINI COOPER :: North American Motoring - Sprint Booster | This thread | Refback | Mar 7th, 2009 01:34 PM | |
| sprint booster - Mini-Mods Forums | This thread | Refback | Nov 13th, 2008 06:57 PM | |
| sprint booster - Mini-Mods Forums | This thread | Refback | Nov 13th, 2008 05:49 PM | |
| Sparco Sprint | leon1982 | First Generation Interior & Ice | 7 | Oct 22nd, 2003 02:26 PM |
| Abingdon Sprint - JCW Report | John Cooper Works | MINI in Motorsport | 13 | Jun 14th, 2002 03:42 AM |
| Sprint @ Abingdon | Dom | MINI in Motorsport | 14 | Apr 5th, 2002 09:40 AM |
| MINI Sprint | monsta | Future Variants | 5 | Feb 28th, 2002 07:02 AM |
