| If you didnt get the wiring loom, there was a little box connected to the bulkhead with the electrics. I think you may need it. You would be better leaving out the electrics, removing all the vacuum pipe alterations, and the flap at the back of the airbox. Then you will be running it like the motorsport version and the engine can breathe much better below 4500rpm. Many people fit the JCW version and then remove the flap at the back for more air. So its pointless connecting the electrics and the vacuum system, to operate a flap which isnt there. ![]() |
| Thanks for the information PMP, if I can't get any wiring info then that may be an option. I understand what you mean about the flap, but I would like to at least try to put the wiring in if possible. Maybe someone has a bit more information they can supply. Chilli_Red |
| Had a look at mine and ther is more than just a couple of wires, they go to the ECU and also go to a block?? then they go to another plug on the other side of the air box. I will go out and see if I can get some good photos for you. but it is not as simple as two wries. |
| Go for the motorsport modification like PMP is talking about. I bought his old airbox and fitted it on Saturday. All you have to do is remove;
Its not actually that loud until you go over 3K RPM. The motorsport one has metal plate covering the hole for the flap mechanism and thats the only difference. I couldn't be annoyed with having to track cables and pipes would have taken hours. Should have it fitted in an hour and half. |
| I am going to be putting all of the wiring / vacuum kit on ebay soon if you mean that? Have a look here... RealOEM.COM * BMW R53 Cooper S JOHN COOPER WORKS AIR FILTER SYSTEM I have the following... 03 VACUUM HOSE J. COOPER WORKS 1 13720396432 +cor 05 VACUUM RESERVOIR J. COOPER WORKS 1 13720396430 +core 06 VACUUM CONTROL - ENGINE J. COOPER WORKS 1 13720396431 +core 07 ELECTR.VALVE J. COOPER WORKS 1 11740396414 +core 10 AIR FILTER CONTROL UNIT J. COOPER WORKS 1 13700393779 +core Mine is the motorsport set up and its much louder under full throttle with a slight increase in air suction (wooshing not induction roar) noise under halft throttle and normal if pootling. |
| Tags: cai, jcw, wiring |
| JCW Airbox | ccollyer | First Generation Works | 6 | Oct 5th, 2007 12:28 PM |
| JCW Engine Kit & JCW Airbox | venox22 | First Generation MINI Tuning | 2 | Aug 26th, 2005 12:01 PM |
| JCW Airbox | MiniSMan | First Generation MINI Tuning | 4 | Jul 17th, 2005 12:04 AM |
