Swapping from a 15% pulley to 17% pulley - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Apr 22nd, 2008, 04:48 PM
Jaw_F430's Avatar
M3 CSL
Local Time: 07:07 PM
United Kingdom Male View Jaw_F430's Solid Black & Body Color 1st Gen MINI Cooper S Profile View Jaw_F430's Classified Ads
Hi all
Having fitted my new head the boost pressure has dropped and now I am thinking of upping the boost more by switching to a 17% pulley.
Just to get a collective answer does anyone see any disadvantages from switching to a 17% pulley? (or advantages apart from more power)
I initially went for the 15% as this is at the top end of the operating scale for the s/c before excessive heat is produced and it seemed the safer option as I had stock I/C.
James
Old Apr 22nd, 2008, 06:05 PM
sam_a156's Avatar
Flying Finn
Send a message via Skype™ to sam_a156
Local Time: 08:07 PM
Poland Male View sam_a156's Dark Silver & Black 1st Gen MINI Cooper S Profile View sam_a156's Classified Ads
Keen to hear comments on this too. I also saw a tangible drop in boost.
My -17% Alta v2.0 is already on its way. Going to swap my current JCW & +3% crank setup to oem crank and -17%.
Personally I would think that going for bigger reduction might not allow to raise the rev limiter so much as -15% due to overspinning the s/c. Suppose 7400/7500 should still be ok though(?)
Sam
Old Apr 22nd, 2008, 06:57 PM
Jaw_F430's Avatar
M3 CSL
Sam
Thats what I was thinking Sam as my map may end up at 8k redline. Boost shown on gauge after fitting few parts is 14-15psi
Old Apr 22nd, 2008, 11:01 PM
Send a message via MSN to GRSmotorsport
United Kingdom View GRSmotorsport's Classified Ads
I'm running a 17% pulley with no problem at all (touch wood!). Wouldn't worry too much about the slight loss in boost. You want maximum BHP with the minimum amount of boost. I'm peaking at 15.5psi but still seeing 250-256bhp. I'm not running a lighter crank pulley either.....
Graham
Old Apr 23rd, 2008, 04:45 PM
Jaw_F430's Avatar
M3 CSL
Cheers GRS
Do you have a big valve head fitted? And are you running air to air or chargecooler?
Old Apr 23rd, 2008, 04:59 PM
Cheers GRS
Yes I have a West Tuned big valve and flowed head, I'm also running a charge cooler
Graham
Old Apr 23rd, 2008, 10:30 PM
MINI-Morgan's Avatar
MINI Obsessed...
Have you still not got that 17% on yet?? Come on....some of us are even running one with the stock intercooler without any probs!
Old Apr 24th, 2008, 12:01 AM
Silent1's Avatar
Supercharger Noiseaholic
Send a message via MSN to Silent1
Local Time: 06:07 PM
United Kingdom Male View Silent1's Dark Silver & Black 1st Gen MINI Cooper S Profile
Sam
Revving the engine to 7500 RPM with a 17% pulley would spin the supercharger to ~19313RPM that's 3313 RPM over the maximum safe limit of an M45, the thermal inefficiences you're going to encounter at that RPM would almost certainly negate any benefit from spinning it that fast.
At the very least you're going to encounter a drastically shortened service life for the supercharger as well as the fact if it does let go spinning that fast i wouldn't like to guess what else it will take out.
Old Apr 24th, 2008, 06:28 AM
As above comment , but if you dont run to the red line all the time then the only issue could be the premature water pump drive fails and possible cavitation ,again only if very high rpm maintained.
Boost pressure itself is not and indication of how much power you will make -the flow and volume of air is ,what you need is quality of boost not size of boost .
You could for example shove a cork into the intake manifold with a hole in the middle- result would be far higher boost pressure!!! but far less power!!
Quality boost = lowest temp, thus greater density , at the optimum speed of airflow, with minimum turbulence, and drag.
The charger also uses less power to turn when providing quality boost and more power when not
Old Apr 24th, 2008, 05:33 PM
Jaw_F430's Avatar
M3 CSL
I think I will stick with my 15%. (looked on NAM as well and a lot of them use 15% with good power made)
If I can make around 230WHP with my current spec I will be happy (thinking of going back to stock exhaust as well as JCW with Janspeed mani is quite loud IMO)
Cheers for all your comments guys
Old Apr 24th, 2008, 05:45 PM
MINI Obsessed...
You have to consider your end result. 17% will be faster if you maintain good temps and dont rev as high. 15% will be better at higher revs. You decide if you want more torque or higher revs I voted torque as I hate driving type-r's
15% SC + 2% crank pulley or 17% SC pulley? mobile23 First Generation MINI Tuning 49 Jul 7th, 2007 05:19 AM
How much more HP/TQ does the 19% pulley give over a 15% pulley? 05MCSConvertible First Generation MINI Tuning 1 Sep 27th, 2005 10:06 PM
stock MCS crank pulley the same as stock MC pulley? mini_macky First Generation MINI Tuning 5 Aug 24th, 2005 04:35 PM
Different between 15% and 17% pulley... MiniDSW2005 First Generation MINI Tuning 14 Jan 8th, 2005 03:00 PM
SC Pulley suprchrgdmini First Generation MINI Tuning 13 Feb 16th, 2003 04:20 PM
