Mounting scangauge - Page 3 - MINI Cooper Forum - MINI2 Mini Cooper Forums
  #31 (permalink)
Old Feb 23rd, 2009, 04:26 PM
REDHOT CHILLI COOPER's Avatar
Local Time: 07:07 PM
England
It' well read the fault codes no problem and then just look up on the fault sheet to see what you have.
I bought it originally for resetting the emissions light on the dash after fitting a Janspeed manifold. It comes on every couple of weeks due to the sports cat allowing emissions above the sensor threshold, nothing to worry about it's just a flag but i still wanted to reset the light.
Anyway once you plug in you realise just how many other options and readings you can look at so I bet you'll end up fitting it on the dash .
Really easy to just plug into the OBD socket and run the cable up inside the dash and pop it out in the right hand side corner. Or just as easy to plug'n play if you like.
  #32 (permalink)
Old Feb 23rd, 2009, 04:57 PM
Chilli
Local Time: 06:07 PM
Thanks so much for your help, going to order one tomorrow
LinkBacks (?)
LinkBack to this Thread: http://www.mini2.com/forum/first-generation-mini-tuning/157149-mounting-scangauge.html
Posted By For Type Date
Fuel Computer - Detailing World This thread Refback Feb 26th, 2009 08:42 AM
Utilizing Scangauge Readings MINIAC First Generation MINI Tuning 7 Oct 21st, 2008 07:59 AM
Scangauge 2 Rigsey First Generation MINI Tuning 107 May 7th, 2008 08:43 AM
Scangauge XGauge Boost MINIAC First Generation MINI Tuning 4 May 2nd, 2008 11:03 AM
Scangauge VS. DashDyno VS. G-Tech brainycheddar First Generation Interior & Ice 0 Dec 13th, 2007 05:29 PM
IPOD Mounting and needs Rabboeni First Generation Interior & Ice 22 Mar 5th, 2004 07:28 PM
