| Mine is in the center-stack cubby mounted on a home-made bracket: More pictures ... Last edited by MINIAC; Jun 6th, 2010 at 03:50 PM. Reason: fix link |
| EB/W R53 MCS Highly Modified |
| it jsut plugs into the obd2 port, so it's really easy to install, the x-gauge feature allows you to add a realtime HP readout. the only problem is the refresh rate is rather slow so it make accurate readings in first or second gear tough. Mods: |
| usually have both the car and the scangauge off when you plug it in. when everything is hooked up, start the car, and it should say "connecting" after a while it goes to the screen that you were on last time the car was on. Mods: |
| I have try all modes but doesn't connect. On my M3 has connected in about 15 seconds in ISO mode. I really not understand what is wrong. I have trying an hour today but nothing. The car is Cooper S 2002/october. Does anybody know where could be a problem? |
| Here's mine... |
| Tags: scangauge |
LinkBacks (?)
LinkBack to this Thread: http://www.mini2.com/forum/first-generation-mini-tuning/157149-mounting-scangauge.html | ||||
| Fuel Computer - Detailing World | This thread | Refback | Feb 26th, 2009 08:42 AM | |
| Utilizing Scangauge Readings | MINIAC | First Generation MINI Tuning | 7 | Oct 21st, 2008 07:59 AM |
| Scangauge 2 | Rigsey | First Generation MINI Tuning | 107 | May 7th, 2008 08:43 AM |
| Scangauge XGauge Boost | MINIAC | First Generation MINI Tuning | 4 | May 2nd, 2008 11:03 AM |
| Scangauge VS. DashDyno VS. G-Tech | brainycheddar | First Generation Interior & Ice | 0 | Dec 13th, 2007 05:29 PM |
| IPOD Mounting and needs | Rabboeni | First Generation Interior & Ice | 22 | Mar 5th, 2004 07:28 PM |
