| After the front were done I found the back to be a little loose! The rear bushes work a treat! Again there are 2 brands to choose from: Superflex and Powerflex, the Superflex are a full metal bodied press in bush, the Powerflex are push in plugs which fill the voids in the standard mini bush. On the front I would always fit Superflex On the rear I would fit Powerflex as they wont require a wheel alignment and will do the same job. |
| So, an update on where I'm up to... Unfortunately the garage I normally use in London is booked up until sometime next year, and 1320 don't work on weekends during the summer, so found a random garage in Kilburn that sounded very excited about fitting some Superflex bushes (a good sign, I think) and ordered myself some bushes from Superflex direct. Lets hope this Kilburn garage manages to fit them without destroying the alignment or indeed anything else! I'll post an update once they're done next week... |
| I don't blame anyone for not working weekends in this weather, outside temp was reading 27 on the way home today!! ![]() I took a day off work as I had a few days to use up before it changed over , good look mate. This is one mod you wont regret, just as long as the garage get it right that is ![]() |
| Actually ignore my question...... |
| You can do them on the car , did mine this weekend, bit of a pain but saves dropping the sub frame. I would buy the tool from BMW though as most of my times was spent making up bits to do the job. Stock Cooper S @270+BHP 13.7@103.9www.minitorque.com ULTIMATE BMW SHOW 21st Sept 2008- Santa Pod Raceway |
| Tags: handling, lsd, performance, torque steer |
| torque steer? | minigt3 | Second Generation MINI Cooper S | 12 | Feb 20th, 2007 04:07 AM |
| Torque Steer? | darster | First Generation MINI Cooper S | 11 | Sep 15th, 2006 03:51 PM |
| Torque Steer...Remedies? maybe not LSD... | TonyB | First Generation MINI Tuning | 41 | Jan 24th, 2004 03:18 PM |
| Torque Steer Test and Comments, please. | Cape Cod MINI | First Generation MINI Cooper S | 14 | Mar 20th, 2003 11:03 AM |
| torque steer in Cooper S? | TonyC | First Generation MINI Cooper S | 5 | Jan 16th, 2002 08:06 PM |
