Is this an original SC pulley? - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jul 15th, 2008, 03:32 PM
Local Time: 08:10 PM
Norway
I went to a mechanic today to try to locate the source of a whine my car (2002 MCS) makes, he was confused by my SC pulley, he thought it didn't look stock. What do you think?
He tried to measure it, but it proved difficult, he measured about 55mm, which according to what I have found on the Internet is not stock. I looked for markings of any kind on the pulley, but could only find some unreadable numbers on an orange looking label. The car is stock according to previous owner and has no other visible mods.
He also noticed that the belt tightener (what is the correct word for this part?) looked like it was pushing as far as it could, i.e. the spring was all the way out.
Old Jul 15th, 2008, 05:44 PM
Jaw_F430's Avatar
M3 CSL
Local Time: 07:10 PM
United Kingdom Male View Jaw_F430's Solid Black & Body Color 1st Gen MINI Cooper S Profile View Jaw_F430's Classified Ads
That is not a stock pulley. It has been changed but could be stock size, no way of telling without measuring accurately. Does not look like a good job either as it looks like the S/C shaft is drilled and tapped and a bolt is used with a thick washer to hold the pulley in place. Must be a 2 piece pulley though otherwise it would spin on the S/C shaft.
Your S/C belt has prob stretched to its limit if the tensioner is fully extended.
Stock Cooper S @270+BHP 13.7@103.9
www.minitorque.com
ULTIMATE BMW SHOW 21st Sept 2008- Santa Pod Raceway
Old Jul 17th, 2008, 11:48 AM
Norway
I talked to my dealer and the guy I talked to claimed that the stock pulley was mounted on a bolt like it looks like mine is. Are you sure it is not stock? I am planing on switching to a Alta 15% pulley, would this be harder to install if the SC shaft has been modified?
Old Jul 17th, 2008, 04:56 PM
Jaw_F430's Avatar
M3 CSL
Well all the stock ones I have seen do not look like yours, also all the stock ones are an interference fit onto the S/C shaft. The pulley I have on mine is a 2 piece pulley and it is a taper lock.
Just went to have a look at my spare S/C and the shaft is drilled and tapped but it is not used to mount the pulley. There is normally a black plastic cover that pushes into the thread. I have took some pics of the stock pulley for you.
ID:	148652   Click image for larger version
ID:	148653   Click image for larger version
www.minitorque.com
Old Jul 18th, 2008, 07:22 PM
Damo's Avatar
Lights are on but...
Send a message via MSN to Damo
United Kingdom Male View Damo's Solid Black & White 1st Gen MINI Cooper S Profile View Damo's Classified Ads
Jaw speaketh (and showeth) the truth
Need an original 05 S pulley Corman First Generation Faults & Fixes 7 Jul 9th, 2008 02:28 AM
Original Crank/Pulley Ratio tirlibibi First Generation MINI Tuning 0 Mar 17th, 2008 11:20 AM
Original GTT 280 First Generation MINI Cooper S 7 Jun 20th, 2003 01:42 AM
