| | LinkBack (4) | Thread Tools | Rate Thread |
| Just had a reply from Tony at MINI Motorsport Centre who has quoted me £80 + vat to fit the pulley & belt which I think is quite reasonable after reading the Alta fitting instructions. As i've now aquired the crank pulley & some Eibachs I might just get them to do the lot. Can drop the misses off shopping in Brighton or Worthing or something ![]() MAFFA |
| you wont need a re-map mate but the best plugs are the jcw spec nkg's they cost but there quite hardy i get mine from here Sparkplugs UK NGK Champion Denso Sparkplug, Glowplug and Lambda Sensors type this code into the part finder BKR7EQUP and obviously you need 4 plugs the price on there is half what mini charge even me with a trade account |
| Not sure i'd risk it as I know 1st hand the risks of running plugs that aren't cold enough. Melted the end of a spark plug off whilst running a 12 second 1/4 in one of my Subaru's. Cost me £2k in engine building for the sake of an extra £40 on plugs ![]() ![]() After everyone saying how much extra heat is generated with a smaller pulley i'm not going to skimp this time. MAFFA |
| the NGK irridium range 7s are just as good mate, and all it is is they have a single electrode not the 4 way slit one. The temp range and material is the same, just the electrode design is different. Sparkplugs UK NGK Champion Denso Sparkplug, Glowplug and Lambda Sensors do these for about £30 50k miles on a 15% reduced pulley car running way over 200bhp ... and never had a set with any daage showing or cylinder temp issuies or detonation. |
| Funny you should say that as I was looking at some threads on here last night & found the part number of BKR7EIX-11 ![]() I then started watching these: £31.50 delivered seems reasonable for a highly recommended plug. Especially when compared to the BKR7EQUP at £15 a plug. I did read around & there are views that these plugs are as good as each other & that the platinums are just so expensive because they're recommended for the Works MAFFA |
| Tags: pulley, reduction, supercharger |
LinkBacks (?)
LinkBack to this Thread: http://www.mini2.com/forum/first-generation-mini-tuning/162079-guinea-pig-kmt-15-reduction-pulley.html | ||||
| MAFFA's Mini - Mini Torque | This thread | Pingback | Feb 6th, 2009 11:22 PM | |
| MINI COOPER :: North American Motoring - kmt pulley any new thoughts | This thread | Refback | Jan 2nd, 2009 01:03 AM | |
| Supercharger Pulleys? Whats the difference? - Mini Torque | This thread | Pingback | Dec 16th, 2008 10:15 PM | |
| PERFORMANCE AND TUNING on MINI2 - Fuel For Your MINI Obsession - MINI Cooper - S - One - Diesel - Works - Cabrio | BoardReader | This thread | Refback | Dec 8th, 2008 01:07 AM | |
| pulley reduction | zippyy | First Generation MINI Tuning | 7 | Nov 28th, 2006 12:47 AM |
| question about pulley reduction | MINI-LOVER | First Generation MINI Tuning | 3 | May 16th, 2006 08:46 AM |
| 15% reduction pulley | ScottishcooperS | First Generation MINI Tuning | 27 | Dec 7th, 2005 08:25 AM |
| 15% reduction pulley | Idontbrakeforcorners | First Generation MINI Tuning | 13 | Dec 23rd, 2004 01:09 AM |
| Chequered Decal.. Guinea pig WANTED. | Kev beck | First Generation MINI Exterior | 16 | Feb 28th, 2003 07:00 PM |
