| I would normaly fit a smaller belt, dont use your old belt as a measure as it will of streched! Once new belt is fitted you need to look at the tensioner stop to unsure it has enough movement left, a belt too long will break the tensioner stop off. |
| There have been a few posts on this between MINI2 and NAM. I believe that someone showed that you should try to "split" the lock hole for the tensioner. This hole is visable if you shine a light down towards the pulley. The little hole is used by sticking somthing like a small allen key in it to keep the tensioner loose. With a 15% pulley many folks have run stock. I did this for a while but soon realized that my belt was actually slipping so I moved to a smaller belt and found the new power. I highly recommend a smaller belt as well. If you are doing it yourself try to borrow a tensioner tool as it can be a pain to get the tension off of the belt without it. |
| I'll more than likely give these guys a call: MINI Motorsport Centre They're only down the road ![]() MAFFA |
| Tags: belt, pulley, reduction, supercharger |
| Supercharger Belt | KAS66 | First Generation MINI Tuning | 12 | Aug 8th, 2007 06:41 AM |
| Reduced pulley and belt...what's the worst that could happen? | SiBurt | First Generation MINI Tuning | 8 | Feb 22nd, 2006 09:50 PM |
| Reduced Supercharger Pulley - what's involved? | Roofas | First Generation MINI Tuning | 6 | Aug 4th, 2005 09:13 PM |
| Reduced size Supercharger pully wheel | PeachtreeCityCooperS | First Generation MINI Tuning | 4 | Sep 20th, 2003 11:39 PM |
