Pulley sizes On cooper S? JCW? etc. - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jan 17th, 2009, 05:45 PM
Local Time: 04:48 PM
United Kingdom View deanspoors's Classified Ads
Ok so I've got a mini cooper with the JCW kit fitted, can somebody please tell me what these reduced pulleys are all about?
Whats the difference between the cooper S, and JCW supercharger, what size pulleys do these have as standard, and what sort of increase in BHP should i expect from a standard 200bhp JCW mini from replacing pulley to a 15% or a 17%
thanks, Dean
Old Jan 17th, 2009, 05:49 PM
r1_kde's Avatar
JCW 210 apparently not!
United Kingdom View r1_kde's Classified Ads
Don't know the Bhp changes, it really depends on your engine and the actual power you have... the JCW pulley is about 11% reduced over the stock S also the pre face lift does not have teflon coated rotors on the stock s but the jcw always has Teflon coated
Though my JCW has 193.5Bhp and mine is the 210 version
Old Jan 17th, 2009, 09:15 PM
MINI-Morgan's Avatar
MINI Obsessed...
For everyday power increased id put a GRS intercooler and 17% pulley on there You'll feel a nice difference around town and when you really put your food down.
Old Jan 18th, 2009, 12:45 AM
Local Time: 02:48 AM
Australia View D-MAN's Classified Ads
thanks, Dean
Gains will be minimal
I swapped my 11.5% JCW pulley to a 16% and got just over 4hp
Old Jan 18th, 2009, 12:51 AM
Eds
Local Time: 09:48 AM
Canada Male
With the right ecu tune, the gain on 15-17% reduced pulley will be greater than 4 HP over the 10.5% (that's not a typo) JCW pulley. I have seen it myself during dyno tuning sessions. Many JCW owners switched to 15% up and were very happy on how much it changed.
04 MCS IB/W : Sport Package : Xenons : Moonroof : S2 Mods.
Old Jan 18th, 2009, 01:23 AM
blaze6's Avatar
United Kingdom Male View blaze6's Classified Ads
thanks, Dean
someone has done some monitoring of supercharger boost/inlet temps, i need to find the link, i think they worked out that 16% reduction gives you the best most consistent performance gain throughout the rev range, with a higher %, heat becomes too sig a factor at the top end, any less % and you loose a little low down torque. don't know if these figures are def accurate.
personally, i'd want to preserve the longevity of my supercharger. i'm not sure what the tolerances of the eaton are supposed to be.....i've got a 17% on my car at the moment, i am thinking about changing to a 15% and combining it with a W2A grs IC. that should give good boost all the time and hopefully?? stay within the tolerances of my supercharger too.
i find on my daily commute, my GRS a2a gets heat soaked and doesn't work that well, though it's much better than the GP IC.
if you've already got a jcw 10.5% / 11.5% pulley, presumably if you're a jcw you've got the 380cc injectors and gp intercooler? best thing you could do is either just get an ecu remap or add a Big Valve Head, aftermarket exhaust system and get a remap. a further reduction to your pulley may not add that much more....and i think the jcw pulleys are a bummer to take off aren't they? so you'd need to buy a supercharger and pay for removing old supercharger and fitting a new one with new pulley. with that money, you could get a tune.
blaze
Old Jan 18th, 2009, 05:48 AM
brainycheddar's Avatar
a.k.a. BrainRush
Local Time: 08:48 AM
United States Male
I read somewhere (MC2 magizine, perhaps?), that a 15% reduction would bring the the eaton to its maximum rated RPM at redline, this is something that I considered before I bought mine. I'm not 100% sure but I think that sounds like an appropriate safety factor for mini to build into the design.
Mods: MiniMania CAI and 15% pulley, Racing Brake front rotors, EBC Green Stuff front pads, ALTA 19mm anti-roll bar
Old Jan 18th, 2009, 10:29 AM
MINI Obsessed...
17% works great but if you live your life above 6K rpm then maybe isnt for you. Dont believe everything you read.....
So if you want a higher torque curve then 17% is best to go for and if you want HP pub talk 15% is better The SC only starts to build real heat from 6,000rpm onward to red line.
Old Jan 18th, 2009, 08:57 PM
The JCW pulley is not 10.5%... FACT
Have you ever measured a JCW pulley? I have, try it and you will see
The gains you are talking about are from a custom tune not the pulley.
The question was how much power will I gain from the pulley - not a pulley and re-tune
Old Jan 19th, 2009, 06:04 AM
Send a message via MSN to Fisher
Slovenia Male View Fisher's Electric Blue & White 1st Gen MINI Cooper S Profile
On the market you can find the several pulleys: 11,5 % ; 15%; 16%; 17%; and 19%.
And all depends what you want. With 11.5 you are the most safetly and cold.
Old Jan 19th, 2009, 11:24 AM
Keano's Avatar
JCW 250
United Kingdom Male View Keano's Solid Black & Body Color 1st Gen MINI Cooper S Profile View Keano's Classified Ads
Was there a significant change in the torque curve?
Running 211whp
Old Jan 19th, 2009, 04:01 PM
Xr3i_Alloys's Avatar
Local Time: 03:48 PM
England View Xr3i_Alloys's Hyper Blue & Body Color 1st Gen MINI Cooper S Profile View Xr3i_Alloys's Classified Ads
it will will bring the torque curve down the revs as you're spinning the SC faster at lower revs
Brilly
Old Jan 20th, 2009, 01:50 AM
No, not really - I got more of a change when I added my EVIL lightweight crank pulley
Old Mar 17th, 2009, 01:10 PM
I live in miami florida and as you know the weather here is really hot. Will a 17% reduction pulley work in this weather?? I use my car to drive to work and for rides in the weekends and of course i step on the gas a few times on the road and go on trips of 2 to 4 hours at 70-100mph speed. do you think heat could be a factor do that this pulley ma also creat more heat do to the mor compresion. what do you recomend? my mecanic says it will not work corectly and that my checkengine light will turn on and if accelerating a lot it will turn the ecu into a safe mode and restrict the gas.
  #15 (permalink)
Old Mar 17th, 2009, 05:57 PM
MINI Obsessed...
What are your temps like there?? if its over 30C i'd stick to a 15% pulley instead. Defiantly get a bigger intercooler like the GRS Motorsport one too
pulley sizes mcbeal_88 First Generation MINI Tuning 6 Sep 12th, 2008 03:44 PM
:: Snowy Pics of my JCW S :: now with desktop sizes monkeynuts Photos, Photoshops, Videos & Showcases 13 Apr 5th, 2008 02:43 PM
jcw brake sizes alexvw Wheels, Tyres & Brakes 5 Nov 15th, 2007 03:43 AM
JCW Badges Sizes? nial_cooper First Generation MINI Exterior 4 May 19th, 2006 01:53 PM
Smaller pulley on JCW cooper S conversion???? Portised First Generation MINI Cooper S 2 Jan 20th, 2004 05:37 PM
