Reduction Pulley Sizes - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jan 31st, 2009, 11:23 PM
MINIAC's Avatar
Canned
Local Time: 01:25 AM
Reduction pulley sizes are always referenced in terms of percentage. The following table looks at pulley size in terms of diameter and lists diameters (half millimeter sizing) which approximate JCW, 15%, 16%, 17% and 19% offerings.
Code:
65.5mm = Stock
58.0mm = 11.45%
56.0mm = 14.50%
55.0mm = 16.03%
54.5mm = 16.79%
53.0mm = 19.08%
It would be interesting to know the actual diameters for different aftermarket pulleys.
Old Oct 3rd, 2010, 07:18 AM
Send a message via MSN to Fisher
Local Time: 09:25 AM
Slovenia Male View Fisher's Electric Blue & White 1st Gen MINI Cooper S Profile
I can write you for Kavs Motorsport one:
58mm - 11.5%
57mm - 13%
56.5mm - 14%
55.5mm - 15%
55mm - 16%
54.5mm - 17%
53.8mm - 18%
53mm - 19%
52.5mm - 20%
Old Nov 12th, 2010, 06:19 PM
Local Time: 03:25 AM
maybe someone could post up the rotational speeds of the supercharger with each pulley size? that way people can tell which pulley they want to run based on the rpm's of the pulley vs the 14,000 rpms efficiency range of the M45 supercharger.
here is the 19% rate at 7k that i found in another post
17,802rpms at 7,000 rpms
Old Nov 15th, 2010, 01:10 PM
Keano's Avatar
JCW 250
United Kingdom Male View Keano's Solid Black & Body Color 1st Gen MINI Cooper S Profile View Keano's Classified Ads
That information is available on another mini forum
Rounded to the nearest 100rpms engine speed, the 14k 'limit' for the M45 'charger for different pulley sizes is as follows:
Stock @ ~6800
11.5% @ ~6000
14% @ ~5900
15% @ ~5800
16% @ ~5700
17% @ ~5600
18% @ ~5500
19% @ ~5400
Note that the above are rough and are assuming a stock CP size.
Running 211whp
Who to fit reduction pulley? big pete First Generation MINI Tuning 14 Jan 25th, 2009 05:20 PM
pulley reduction zippyy First Generation MINI Tuning 7 Nov 27th, 2006 11:47 PM
supercharger pulley reduction K9HNY First Generation MINI Cooper S 7 May 4th, 2006 04:24 PM
15% reduction pulley ScottishcooperS First Generation MINI Tuning 27 Dec 7th, 2005 07:25 AM
15% reduction pulley Idontbrakeforcorners First Generation MINI Tuning 13 Dec 23rd, 2004 12:09 AM
