| Engine Coolant? Hi the bottle in my engine at the back which had some blue liquid in it is empty and i dont know what to put in it? it has the sticker on it with a cross to say dont put windscreen washer in it but i dont know what to put in it and i dont want to drive round with it empty as it might be something important! can anyone advise on what i need to put in it? Thankyou |
| Hi thanks for the replies i have just been putting water in it will that damage anything? it seems to empty rather quickly aswell!! do it have anything to do with the radiator? im going look up on maintenance as i dont know much as you can probs tell! Thankyou |
| As has been said It is important !............keep the coolant level between the max. and min. marks on the "bottle" or your engine may overheat and be damaged. If the level is dropping you need to get this checked out asap, as you could have something like the thermostat or radiator leaking. Use a long-life ethylene glycol based antifreeze (50/50 mix antifreeze water). BMW coolant will definitely be right spec. but may be more expensive than somewhere like Halfords. |
| ^^^ what he said, if you're having to fill up regularly, then something may be amiss. if you've always used water over the recent period of subzero temps, thatmay be a factor, as it's possible your coolant % may have fallen and freezing point risen, fluid may have frozen and then thawed in your cooling system which may or may not acuse problems if this has happened. play safe and get a mechanic to check things out, and go easy on the car till it is checked over and keep the levels within normal limits till you do. blaze |
| Problem with Engine Coolant | libby.brown | Second Generation Faults & Fixes | 7 | Apr 11th, 2008 07:28 AM |
| Engine Coolant Resovir Problem???? | MrMackem | Maintenance & MINI Care | 4 | Feb 26th, 2008 09:47 AM |
| changing engine coolant! | bemini | First Generation MINI Tuning | 7 | Jul 19th, 2006 10:21 PM |
| Help!!! Screen Wash In Engine Coolant | Sparkybhoy | Maintenance & MINI Care | 5 | Dec 11th, 2005 08:55 AM |
| Engine coolant in my new Mini S | timmy | Maintenance & MINI Care | 5 | Oct 31st, 2002 01:41 AM |
