| Has anyone looked into putting a limited slip diff into an MCS yet? I take delivery next month and am curious to see how much of a difference it makes. I've been lucky enough to drive someone else's around a track and putting the power down coming out of a corner wasn't as good as I had hoped...inside front wheel is starting to spin a little and it's not as smooth on acceleration as it should be because of that. |
| Re: LSD Simon, are you going to alter the final ratio? Please say you are as most of us here are not happy with the long gearing. It's your chance to change this. Also, any idea how much it would be (in AUstralia)? |
| Ratio Thats the idea, we have succeeded on doing it on the Cooper offering 3 different ratio's, the same will hopefully be said for the S. We are also working on a Close Ratio S/C gear kit, but normal engagement, not Dog. I will post more about these products in the next couple of days. |
| Check out MINIMania at this link. They have a lsd for the MCS at $1,695.00. Might be able to get some feed back from them. Check out the close ratio gear kit for the Cooper too. Interesting. http://new.minimania.com/NewMiniMechanical.cfm Missing my buddies Dan, Ed, and Diane but glad I have three angel buddies , And on a quest to Right Secco's Wrongs |
| limited slip i think you can get the quaife straight from them for $999,, now the real problem is getting it in the car,, looks like you will need to drop the engine down in order to get the transaxel off of it,, then you need to split the transaxel to get the quaife in where it needs to be, no small task or cheap one, if some one knows a good place to get all of this done in the midwest please post it,, cheers |
| More on Limited Slip I have also been checking out the LSD from Quaife. It appears that the labor for this install would be in the $1100 to $1500 range - unless of course you get it done for trade or "Know a guy" however, I can't imagine letting just anyone attempt this. I think the result would be great as the S has a lot of wheel spin under hard cornering. |
| Doesn't the MCS use the same Getrag 6-speed as the Nissan Sentra SER Spec V? It has a limited slip from the factory. I think the Focus SVT uses the same tranny also. Cooper S Chili Red W/White 16x7 BBS RX Borla Exhaust |
| Limited Slip Differential? | Rutabaga | Second Generation MINI Cooper S | 6 | Feb 20th, 2007 02:26 PM |
| Limited Slip Differential | Andromcs | First Generation MINI Tuning | 11 | Oct 4th, 2004 02:30 PM |
| Limited Slip Differential | Andromcs | First Generation MINI Tuning | 29 | Aug 15th, 2004 07:47 PM |
| Quaife limited slip differential for MCS | JNS513 | First Generation MINI Tuning | 2 | Mar 15th, 2003 04:30 AM |
