help with airbox resanator?! - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old May 14th, 2009, 07:16 PM
Local Time: 11:06 AM
I need help removing the resonator which connects to the airbox?
any one know the best way to go around doing this?
thanks in advance
Old May 16th, 2009, 02:19 PM
Local Time: 12:06 PM
Scotland View gsommo's Classified Ads
Im interested to know how to do this to? What happens when it is removed? Does it make the exhaust sound alot better? I am thinking about getting an OBX header too, would this and resonator delete be to loud?
Old May 16th, 2009, 07:40 PM
WHITEY_'s Avatar
thewhitestuff
United Kingdom Male View WHITEY_'s Cosmos Black & Body Color 1st Gen MINI One Profile View WHITEY_'s Classified Ads
He means the resonator for the airbox not the exhaust system.
Old May 17th, 2009, 01:12 PM
Yeh i just saw that oops. What is the airbox resonator anyway is it on one of the airbox pipes, like a section that sticks out in order to reduce noise? Do you not have to cut it off to remove it, or what?
Old May 17th, 2009, 01:33 PM
WHITEY_'s Avatar
thewhitestuff
Yes, if you look above your radiator at the intake air feed, there's a moulded plastic pipe which fits into your airbox to channel cold air into it. There are another 2 small pipes underneath this main air pipe which I think are designed to allow a small amount of air and intake sound to travel down to reduce echo inside the air feed and quieten the sound.
Its an absolute b**** to get off, I think you'll need to get underneath the car to get a good hold on it as the resonater pipes travel down to some sort of box. If you look on RealOEM you'll know what I mean.
Old May 17th, 2009, 03:34 PM
My understanding of the resonator thing, was that the intake pipe that runs from the front of the car where the grill is, to the airbox, on this pipe leading in there is like some extra moulding on the side of this pipe, like a cylinder of plastic that sticks out of the main tube, and this is what reduces noise. I have heard some people say that you can cut this off, but it is no easy job fixing it back up again to being just one smooth pipe.
Old May 20th, 2009, 02:19 PM
ye managed to get it off last week, like you say its a underneath the car job getting the resonator off!
BMC on though and sounds fantastic!
Old May 20th, 2009, 02:32 PM
WHITEY_'s Avatar
thewhitestuff
Could you put some pics up of the BMC setup? I'm guessing its the BMC CDA?
My airbox... Il Generale First Generation MINI Tuning 3 Aug 24th, 2007 06:33 PM
JCW Airbox MiniSMan First Generation MINI Tuning 4 Jul 17th, 2005 12:04 AM
MCS Airbox Mike Edwards First Generation Faults & Fixes 0 Mar 13th, 2005 06:14 PM
anyone else had a cracked airbox? HarryHBMCC First Generation Faults & Fixes 4 Jan 26th, 2005 10:06 AM
Talking about the Airbox Gardus First Generation MINI Cooper 4 Oct 13th, 2004 12:37 PM
