| Hi mate, i've also just noticed this noise its a very quiet ticking?? im a little concerned as to what it could be as my mini has been in constant use soo i dont think it could be that yours hasn't been in use ![]() if you already know the problem could you let me know asap please if not im taking my car to the garage in my lunch hour at work Thanks x |
| Hi again, Just been speaking to a few people at work that mentioned timing chains adjustment, so im taking mine to the my mates garage whos said he'd have a listen. sam x |
| Well my car has just been run by my friend at his garage and unless you already know what your about to hear you wont like! It's the gearbox gone mate sorry to have to tell you this ![]() im genuinly gutted as i dont earn enough for me to buy one looks like im goin to be off the road for quite some time |
| Is your mini a standard shift or an automatic? If it is a standard shift it could be your throw out bearing. I had one go bad on my in a toyota before and the symptom is an initial quiet ticking on acceleration and eventually the clutch completely goes out and you can no longer disengage to change gears. Just my two cents. But at least it is something else you can mention to the mechanic. Good luck! |
| Are you sure its the gearbox? Can you hear the noise when you are stationary, with the clutch depressed? If yes, then it wont be the gearbox... My 03 MCS has a ticking noise when I accelerate hard, and has been doing so for years. It is generally only noticeable when driving along narrow lanes with walls either side, and I have the window open. Earlier threads suggest that it was the harmonic damper fitted alongside the engine that was causing the problem. All I can say is, I've now driven nearly 203,000 miles and the ticking hasn't caused any other problems. ![]() UJ Club: GB064 |
| well im not sure im having a gearbox specialist look at it, but a few mechanics have now said its the gearbox i'll get a better idea tonite when its been seen to, but thanks for your suggestions i can mention this to the mechanic x |
| Im not sure it could be the wheel bearings as the noise is coming from up front and my timing chain has been checked recently and was fine, and i check my oil every week when washign and polishing |
| Mine does the same its an r53. Not under acceleration though, just while cruising. Sounds like a metalic ticking noise as if a stone is caught in the tyre tread and tapping on the ground. Very quite, you need the windows down to hear. |
| No mines definatley not that i can hear it with the windows up and its been to the gearbox specialist it needs new bearings and seals for the gearbox :L it's guna cost me but hopefuly my parents will bail me out an my mini will be back to its beasty self yaya yayaya yaya |
| I have topped up the oil and the noise has ceased a little bit. It is hardly noticeable now so maybe it was just an oil thing. I had the car sorted earlier in the year as one of the coil springs broke and I had to have the whole cylinder-head cleaned and skimmed as well as a whole new set of coils put in. They then put on a new timing chain as that was out too. I had the car serviced as well as putting new brake pads and disks at the front. All in all the whole cost was about £1300! So I'll be surprised if it's an engine thing. Nice to know that there is help in the forum so replies appreciated. |
| Tags: acceleration, engine, noise, ticking, whistle |
| Ticking noise | tom2005 | First Generation Faults & Fixes | 3 | Aug 25th, 2006 08:07 PM |
| Ticking noise | SiNNeD | First Generation Faults & Fixes | 7 | Mar 14th, 2005 10:32 PM |
| Odd noise when pulling away... | Intrepid | First Generation Faults & Fixes | 7 | Mar 11th, 2005 01:22 PM |
| Annoying ticking sound under acceleration | jblow | First Generation Faults & Fixes | 10 | Nov 30th, 2004 09:21 AM |
| Ticking noise | PmP | First Generation MINI Cooper S | 8 | Apr 3rd, 2004 01:14 AM |
