Problem with PULLY!??? - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Sep 22nd, 2011, 10:33 PM
Local Time: 02:14 PM
So i recently bought a Alta 15% reduction pulley from a web site when i went to put it on i ran into the problem i need a special tool. my buddy tried the old pulley off but it didn't budge. so i ordered the tension tool and the pulley puller. when i installed it. it went on fine the belt i put on was brand new also i received from Napa. now i drove it about 6-700 miles and on the high way the belt broke and when i pulled into a gas station it was leaking something. it also makes a weird noise ever since the new pulley went on.. what could be wrong or just does it need a new belt?
Old Sep 22nd, 2011, 10:47 PM
Local Time: 07:14 PM
Was the belt to tight???
Old Sep 22nd, 2011, 11:09 PM
i dont think so it went on perfect
Old Oct 3rd, 2011, 10:59 PM
Thomas@1320's Avatar
MINI2 Sponsor
What size belt you using, should be something like a 6pk1365-6pk1368
Old Oct 5th, 2011, 05:42 PM
i was using the belt size it said on the instruction sheet to install the pully
Old Oct 5th, 2011, 06:30 PM
MINI2 Sponsor
Maybe you pulled the shaft out of the supercharger, This would then make the belt run out of line and start to frey,then snap.
Your supercharger drives the waterpump so you may have got the mini alittle hot.
Can you measure the first rib again the blower case in any way?
Old Oct 10th, 2011, 09:43 PM
BigBoSS's Avatar
Send a message via ICQ to BigBoSS Send a message via MSN to BigBoSS
Local Time: 06:14 PM
Slovenia Male
i think its the same problem on here that thomas wrote. pulley is missalined
2005 LY/W MINI Cooper Pepper, MTH Tunerfile, 17" S Spoke wheels, white rear lights, Cooper S pedals, OMP upper and lower strut brace
Tags: ,
Please Help M7 16% pully with a 2% crank pully Mike714 First Generation MINI Tuning 8 Jun 1st, 2010 09:28 AM
15% pully vs 17% pully need your help please neemo First Generation MINI Tuning 10 Dec 3rd, 2009 03:38 AM
15% pully addz First Generation MINI Tuning 6 Jul 9th, 2007 08:41 PM
Pully kit 05cooper First Generation MINI Tuning 7 Jan 9th, 2006 07:08 AM
Just a JCW pully Jaffa Racer First Generation MINI Tuning 4 Jun 11th, 2004 05:22 PM
