| Noise from alternator belt? Hi guys,
If I am correct then on the mini one at the left hand side of the engine close to the front bumper is the alternator belt? Well this belt was replaced in December, just this morning I noticed a slight squeaky noise from the engine, I took some white grease and gently sprayed inside the first top part that the belt goes round, now I assume this will have some sort of bearings? Well once sprayed the noise instantly went away but slowly came back although not as loud, do I just need to let the grease set? Has anyone else had this? Any help would be appreciated |
