Next MCS tuning options? - MINI Cooper Forum
First Generation MINI Tuning
post #1 of 7 (permalink) Old Jan 2nd, 2013, 06:51 PM Thread Starter
Local Time: 03:47 PM
Hi all, OK need some advice from the experienced tuners out there. I've done the easy stuff with my MCS, so far its got K&N panel filter, 15% pulley and a sports exhaust. Whats the next step in terms of BHP per ? I am working to budget so nothing too expensive. I have a few ideas which I will show below and also reasons for not doing some obvious ones. Also the car is only road use, no flat out use, only the occasional traffic light grand prix!
Likely:
Change to a 17% - (would I really notice 2%?)
Performance cam - (no idea what these are like or how good the standard one is)
Water spray for intercooler
Uprated bypass valve
Bigger Injectors (not really sure when theres are neaded)
Unlikely:
Uprated intercooler - (having studied the tests I don't think the standard one is at all bad especially coupled with a water spray, not worth the 500+ for GRS/Forge)
Head porting - (too expensive)
Sport Exhaust manifold/cat (I here no real gain over standard)
thanks for any more ideas or feedback.
Cheers.
Scary_Morris is offline
post #2 of 7 (permalink) Old Jan 2nd, 2013, 08:08 PM Thread Starter
P.s apologies for the bad spelling on my previous post, I was in a hurry!
post #3 of 7 (permalink) Old Jan 2nd, 2013, 08:29 PM
Have a look at the mini torque forum,they are more into there tuning on there,you will get some good feedback there as a lot of the members have tried all the above things you are thinking off?
Kyri1567 is offline
post #4 of 7 (permalink) Old Jan 2nd, 2013, 08:59 PM
231bhp on Lohen's dyno
Hartge220's Avatar
Local Time: 04:47 PM
United Nations Male
I'm running a 15% reduced pulley & was thinking of changing to a 17% but was told that I wouldn't really notice that much difference.
Cam/injectors & a map to suit would be a good move but work out fairly expensive in all.
Hardly heard of anyone using the water spray for the intercooler.
Have a word with the guys at 1320 Mini - Mini Parts - Mini Performance Parts they really know they're stuff about tuning the R53 & could advise on any future mods you might need/prices etc
Hartge220 is offline
post #5 of 7 (permalink) Old Jan 3rd, 2013, 01:55 PM
Hi ya
just my pennies worth
"Likely:
Bigger Injectors (not really sure when theres are needed)"
Right from the above list
15% to 17% would not waist your money, no real gain it will only move your power band and you will start runnining it to other problems heat wise in the summer
1320 cat cams are very good from what i here, but if you don't get your head flowed you will not get the benefit from it, so personally don't waist your money till you have the head done
water spray i would not bother if your standard ic will be running far to hot to make a difference
bypass valve just mod your own one do the vgs mod to it, and set the butterfly up properly this will give you the same effect as the detriot tuned one or similar, the bypass valve will only give you more power if its not set up properly otherwise no real advantage
bigger injectors ok but you will need a remap to get full potential from them and with out a good head, cam, inter cooler and exhaust it will be lost
as you start to push more power from you engine you need to change you exhaust manifold you can get one cheep OBX are not to expensive and close copy to the super sprint ones i think
Unlikely:
from above
uprated ic look on ebay get one from a mini GP and do the mod, the standerd min ones are not very good soon as you start to tune the the car soon as the warmer weather comes when you start to push it any power gains you thought you had will be lost due to high air temps in you inlet track causing you to loose power
again you dont really need water spray (water meth may be but you have a way to go before you can use that
head porting is not to bad depending on what you want seen basic jobs for 500 ish but a good cylinder haed porting job will open up a lot more scope for power
Performance heads | Minispeed for Mini Parts, Servicing and Repairs
exhaust manifold there are gains and will be more noticeable when you have the correct set up
personaly spend your money in the correct places or you will be rebuilding you engine
my advice
buy your self a good cold air intake system this will be better than the panel filter, stick with your 15% pulley, change your spark plugs to NGK BKR7EIX or similar which you should have done all ready when you put the pulley on,
get a GRS or mini gp ic you can keep an eye open in the classifieds here at mini2 of keep an eye open on ebay for a second hand one.
then exhaust manifold, injectors and remap, head and cam and re remap
remap you should go to 1320 mini.
also a thing to take in to consideration is has you car got a LSD you may need one with extra power, as you push the power you will need to think about clutch and flywheel assy
but most important before you start to tune your car make shore all you suspension and brake can handle it
my advise speak to 1320 mini save your hard earned then go see them
hope this help
marque is offline
post #6 of 7 (permalink) Old Jan 3rd, 2013, 02:25 PM
Quoted: 53 Post(s)
Of course you could always leave it just as it comes and save heaps of money, they arent slow cars to start off with after all.
The Nun is offline
post #7 of 7 (permalink) Old Jan 4th, 2013, 04:40 PM Thread Starter
Ok thanks for the info. Yes I've had the plugs done already.
I'll take your advice onboard.
