Performance cams - MINI Cooper Forum
Go Back   MINI Cooper Forum > MINI Technical Forums > MINI Engine & Drivetrain Tuning > First Generation MINI Tuning
Performance / tuning parts centre Essex, London, Kent ? Ellies Mini General Discussion 0 May 22nd, 2013 09:01 AM
Performance loss and noise??? Scary_Morris First Generation MINI Tuning 14 May 14th, 2013 08:04 PM
Old Dec 27th, 2013, 02:40 PM
Local Time: 07:37 AM
Performance cams
Hi Ya all,
Just done a search for performance cams for a cooper s. I'm thinking of it as my next mod. All the search results seem to be quite old (5-6years ago). Has the market moved on at all? Got any new profiles that might be worth a look? I'd be looking a a good road cam, not race or track day and to work with a standard head.
Any feedback would be great.
Thanks in advance.
Old Dec 27th, 2013, 03:26 PM
Local Time: 08:37 AM
United Kingdom Male View Blusox's Laser Blue & Body Color 1st Gen MINI Cooper S Profile View Blusox's Classified Ads
I got a camshaft from kent cams years ago for my first MCS never got around to fitting it though so couldn't advise on any gains I'm afraid. If you want to try it then let me know and I'll lend it to you
Old Dec 27th, 2013, 04:27 PM
Thanks Any idea what spec it is/model number?
Can't say Kent got much of a mension in the old reviews I read, but I know they used to be a big name in performance cams.
How much would you want to sell it for?
Old Dec 27th, 2013, 06:28 PM
It's their MINI01 version. Stated as being for the cooper engine but I was told at the time that it was good for the S too as it uses the same camshaft. Might want to check that though. I'll PM you with a price.
Old Jan 4th, 2014, 03:42 AM
I'm looking to buy a fast road cam but want to find out peoples opinions on what they have had and what they think about different brands? Also what kind of supporting mods would be involved with an uprated cam?
Old Jan 4th, 2014, 04:39 PM
Hi ya
I take it if you guys that are thinking of cams, you have done All the normal mods
Ie : Modded air boxes or cold air intakes, SC pulleys (if you have an MCS), exhaust manifold and cat back or modded exhaust, fuel injectors, plugs and coil pack and wires, reworked bypass valve (MCS). All this can be done with out remapping but to get the full potential from the injectors they will need to be coded using bmw software which is available. The mini DME will self adjust and will learn to a degree
There are a few good cams around on the market depending what you want from them. Low down and mid range or balls out to the redline and not much under 4000, most things are a compromise.
one thing to think about is some of the cams will require a remap when you install the cam to get the maximum potential from them or even get them to run right.
Putting a cam in to standard non modified head I would say is a waist of money for the gain.
Money that could be spend on ether brakes or suspension or even a remap depending how strong your engine is.
To unlock the full potential of a cam I would suggest a good gas flowed head, with standard valves or bigger depending on your requirements and budget a flowed and matched intake manifold and get the exhaust manifold matched to the head. But if you get a head gas flowed ask what cam they would match to the head work this is where the mine field and the BS starts
From what I have been told A good drop in cam is a crower NS1 with the cam timing set up properly this will work ok with out a remap. With a head and intake manifold You can get good power this way.
But as I say to unlock it full potential you would really need a remap
If your going for a head, intake, cam and remap (FA53) I would say NS2, mega mini cam if you can get one or the one 1320 have developed with cat cams, these are all good.
Sorry for yapping on but it takes a lot of thought and do not rush in and waist your hard earned money
Here are some links that may help
http://www.1320.co.uk
http://www.lohen.co.uk/home.html
http://www.thumperheads.com
http://www.vecchio.co.uk
Hope this helps
Old Jan 7th, 2014, 10:27 AM
Keano's Avatar
JCW 250
United Kingdom Male View Keano's Solid Black & Body Color 1st Gen MINI Cooper S Profile View Keano's Classified Ads
Cat cam is one of the most recent new cams for the R53 - 1320 can sort you out there.
Schreick (or however you spell it ) is good for top end.
Newman good for mid range.
Cat cam seems to be able to do both!
I had a newman with a tune and picked up around 20hp but the driveability improvement was more important than peak figures. The cat cam basically manages to do what the newman does but more of it all - does cost more than the newman though.
Agree with the above that its probably a good idea to fit the cam as part of a wider array of matching mods to make the most of it. What mods do you already have fitted?
Running 211whp
Old Jan 7th, 2014, 08:49 PM
Got the normal mods done, apart from injectors, but I am aware they would need changing for any more mods. Would a cam really be a waste without head work and port matching? I don't really want to get that far into the engine and all the extra expense! I know it would be better in an ideal world but not for now.
I don't want a race cam, fast road would do it.
Keano, did you have all the port work done?
Old Jan 7th, 2014, 08:51 PM
Perhaps the guys at 1320 would know how their cat cam performs in a standard trim head. I could see what they say.
Old Jan 7th, 2014, 10:45 PM
Hi ya
I would say the crower ns1 would work ok with a standard head and standard map, If you don't want to go full out on the engine work and remaps
I dont know what mods you have but if your running CAI, SC pulley, bigger injectors, plugs, better ic and manifold.
It will give you a gain, how much thats hard to say it depends how heathy you engine is and the product you all ready have fitted, same with every engine mod
1320, lohan are very good they will be able to help you
What mods do you have we may be able to give advice on other option to get power :-)
Hope this is of some help happy cam hunting
Old Jan 8th, 2014, 08:46 AM
Keano's Avatar
JCW 250
What mods do you have?
What are your goals? (fast road? track?)
A cam is worth while definitely, but I was just meaning that if you were going further with your tuning (ie towards BVH say) then doing it as a job lot would be best and that tuning for a cam is recommended so to save getting it mapped and then have to map it again once further mods were done, I was suggesting to do it all at once
ie map and cam is best done as the last engine mod rather than first before then adding a pulley / manifold etc. Make sense?
My car had a JCW head so some exhaust port work over the S head.
You will get good gains from fitting a cam - its the next best mod in terms of kick in the pants after the pulley
Yes Im pretty sure 1320 will have that info - they've got a huge database of cars they've tuned for comparisons sake (mine will be on there in various guises). Worth giving your tuner of preference a call to discuss your needs or feel free to post up more info on your goals and people will be able to provide recommendations based on their experiences eg fast road only I would aim to improve the mid range to make it punchy / give it grunt (newman/cat cam) whereas if you are on track the focus would be to keep temps down and improve the top end more (schrick)...
Running 211whp
Old Jan 8th, 2014, 08:51 AM
Keano's Avatar
JCW 250
Quote: Originally Posted by marque (original)
Hi ya
The NS1 is like a 'soft' newman so lfit and duration is on the softer side so lesser gains but not too aggressive so depending on goals may be a good shout.
Personally, if I was going to the expense of changing the cam I would want more than that. I would also want to tune for the cam to optimise it (fitting the newman without a tune on mine gave a ~30bhp gain but it was then tuned to make it 'safer' back down to around a 20bhp gain) and to ensure its safe - I wouldn't get the NS1 myself as I would want more power
The NS2 is similar to the newman.
Running 211whp
» Recent Threads
Buying a cat D insurance loss
Apr 4th, 2014 09:12 PM
Last post by The Nun
Today 07:37 AM
5 Replies, 308 Views
Caravanning with a Clubman
Apr 13th, 2014 08:21 PM
Today 07:34 AM
8 Replies, 279 Views
How to Retrofit the Spacesaver Spare Wheel
Dec 6th, 2011 10:40 PM
by mab01uk
Last post by scooper dooper
Today 06:02 AM
43 Replies, 29,023 Views
Engine mounts
Dec 22nd, 2013 07:47 PM
Last post by Rally370
Today 02:04 AM
1 Replies, 669 Views
R50 Short shift - what's the deal with this?
Apr 6th, 2014 04:14 PM
Today 02:01 AM
2 Replies, 221 Views
Which Used Mini
Today 12:31 AM
by UKNY
Last post by UKNY
Today 12:41 AM
2 Replies, 83 Views
Mini One Inspection 2 HELP
Yesterday 10:10 PM
Last post by minikeith
Yesterday 11:18 PM
2 Replies, 92 Views
New to this! No hot air in the car!
Yesterday 03:37 PM
Last post by mab01uk
Yesterday 10:57 PM
4 Replies, 151 Views
Where can I buy Spare wheel carrier for r50!
Yesterday 07:28 PM
Yesterday 10:48 PM
1 Replies, 92 Views
no tyre grip on cooper s in wet
Apr 6th, 2014 08:17 AM
Last post by Stoo Med
Yesterday 08:53 PM
12 Replies, 618 Views
Head gasket, not always
Apr 15th, 2014 10:32 PM
by Kilty
Last post by Kilty
Yesterday 08:44 PM
2 Replies, 194 Views
Bonnet won't open
Jan 18th, 2011 06:16 PM
Last post by Kilty
Yesterday 08:29 PM
6 Replies, 5,766 Views
Fuel additive eolys 176
Jan 24th, 2012 03:20 PM
by FATT
Last post by adriancooper111
Yesterday 06:53 PM
10 Replies, 5,613 Views
2007 Cooper D (r56) - How to look after her and what to look for when buying
Apr 15th, 2014 01:10 PM
by hyvrid
Last post by MiniDeLux
Yesterday 06:45 PM
5 Replies, 254 Views
Mysterious Oil Leak :(
Yesterday 12:23 PM
by phoebe
Yesterday 06:36 PM
2 Replies, 129 Views
stop start nightmare PLEASE HELP !!!!
Apr 2nd, 2014 01:06 PM
Yesterday 06:30 PM
12 Replies, 766 Views
Wheel & Tire Center
