| I haven't messed with mine recently, but as far as I could ever tell with different numbers of discs, it doesn't bother anything. The discs will change color according to how the mixture is. You want them to "bronze", and they obviously get dark if it's too rich, or stay silver if it's too lean. I think it depends on the car, but for the Cooper, you add discs to lean it out. Like Obehave said, it's not a big enough change for the ECU to be affected. Brian - 2005 G Stock '05 MINI or it's back to a Miata in C Stock - 2004 G Stock 2nd place Pro Solo, 9th Place Solo II - 2003 STX 5th place Pro Solo, 6th Place Solo II - 2002 H Stock Pro Solo National Champion |
| Cars tend to run really rich from the factory as a safe guard. Adding just an exhaust isn't going to put your car into a lean situation. Only once you start doing lots of mods will you need to compensate. On The Loose On The Web: www.johnnyboy.ca |
| Ok, so the opinion is there is nothing to worry about as far as a lean condition with just an exhaust change as the ECU can compensate. How about if one frees up the intake as well, can the ECU still compensate. I know the current motorcycle full injection systems can handle either exhaust or intake changes w/o a remap of the injection system, but if you change both, a remap is in order. On my 95 Mitsubishi Eclipse GSX, I had a lot of mods to the intake, exhaust, etc. and no need to worry about mixture. Does the Cooper ECU have such a wide operating band or is it more narrow like a motorcycle? Thanks, Chilli Red over Chilli Red Cooper S, all options but Nav, 2 piece 17" wheels, side moulding body kit, rally lights, black bonnet stripes, Supertrapp exhaust, BMP intake w/cold air mod, and RDR sway bar. Our home page |
| Remap? I need it? Lean mixture? | NewMINI2 | First Generation MINI Tuning | 8 | Mar 14th, 2007 11:26 AM |
| Do you think its rich or lean...... | Paul@1320 | First Generation MINI Tuning | 10 | May 7th, 2006 07:29 AM |
| Is the Cooper S supposed to lean to the right? | GMINI | First Generation Faults & Fixes | 16 | Apr 3rd, 2004 12:08 PM |
| Lean & Mean! | stuartkey | General Discussion | 9 | Jul 14th, 2003 06:31 PM |
