you can fit the rear section of the JCW system with the standard mini cooper s second section ( from the cat back ) it can be cut just forward of the bend before the rear boxes, see link below item i cut at bend before rear box so you basically have a straight pipe.
you can fit the rear back boxes from the JCW exhaust you will need to expand the pipe so it slips on to the JCW back section easy job.
the cat back JCW has a resonator fitted in the centre where as the MCS has a straight throw pipe no biggie
is your system a standard MCS with jcw tips or is it a JCW system
also where is it blowing because there are other options staying with mini parts
Hi guys, bought a complete second hand jcw car back exhaust and went to fit it today, all went smoothly and very simple untill I went to remove the 2nuts that joins the cat to the front pipe, got one nut undo using a 9/16 spanner but the 2nd nut is already round. Going to be using mole grips tomorrow to remove it but now need a new pair of nuts, does anyone know what size nuts these are?
If you want more noise remove the center resonator or fit an exhaust manifold with a sport cat.
Related Threads
MINI Cooper Forum
3.6M posts
159.9K members
Since 2001
