Is a 20% pulley reduction safe if done right? - MINI Cooper Forum
First Generation MINI Tuning
post #1 of 1 (permalink) Old Aug 12th, 2014, 07:26 PM Thread Starter
Local Time: 06:25 PM
I have been looking at the Kavs motorsport 20% pulley reduction to do to my 05 r53 and im wondering if anyone else has tried this. I plan to combine this with my own water to air intercooler (different discussion) and my stage 3 snow system water method system. I feel these combined will solve the problem with excessive heat.
Another issue I hear is belt slippage which can be solved with several of the adjustable belt tensioners that are sold. Also I heard someone say once about a "sticky" belt which I would assume has better grip compared to oem and I'm wondering where I could buy one. My water pump is also new (gates).
My supercharger is freshly rebuilt with new stronger pto gears and 3 warranty and also I am not a race car driver so this won't see constant redline.
Will I need bigger injectors? 400cc? Tune?
Right now I have custom header to tips exhaust, ddm intake, Detroit tuned bpv, fluid damper, Msd coil with ngk iridium.
tomcrowley1995 is offline
Pulley reduction 15-17-19 ? Swarley First Generation MINI Tuning 11 Jul 17th, 2014 10:09 PM
06 R53 with JCW210 - Opinions Wanted on Should I Add 2% OD Crank Pulley? jj-snax First Generation MINI Tuning 14 Feb 10th, 2014 11:08 AM
Need someone to fit my reduction pulley and BPV? edwardtobia First Generation MINI Tuning 2 Jul 30th, 2013 09:10 AM
idler pulley question Miniblu First Generation MINI Cooper S 1 May 25th, 2013 06:00 PM
