DIY Boost Gauge - Help needed - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Apr 14th, 2003, 01:52 PM
graymank's Avatar
Local Time: 11:53 PM
DIY DIY Boost Gauge - Help needed
Help!
I am trying a DIY install a Boost gauge.
('cos the BMP kit is out of my budget)
So I am back to having to install a gauge on my own.
Where do I put in the T-joint to tap the pressure to the sensor?
I see the vaccuum hose going into the Throttle body, but not sure if that the coorect place to tap.
Seems quite far away from manifold itself?
Anyone have any idea?
Would really appreciate your advice!
Old Apr 15th, 2003, 07:46 PM
Local Time: 03:53 PM
I don't believe that there is anywhere to put the t-joint in... if I remember correctly, that one is probably for a turbo system that has small boost lines (silicon tubes) that you can tap to get a boost reading, Our MCS needs to have a sender mounter on the intake to read boost and vacuum. So I'm not sure that will work.
Pilo Racing www.piloracing.com Intakes, Ignitions, Heads, Superchargers and more... stop on in
Old Apr 15th, 2003, 09:45 PM
Send a message via AIM to macncheese Send a message via Yahoo to macncheese
Local Time: 11:53 AM
United States View macncheese's Dark Silver & White 1st Gen MINI Cooper S Profile
Re: DIY Boost Gauge - Help needed
Supercharger is postivie displacement so you'll need to tap in somewhere after the supercharger. I havent installed one so I can't say for sure but I think i remember reading its somewhere on or near the intercooler inlet pipe?
Cheese
Old Apr 16th, 2003, 05:16 AM
jlm
Local Time: 10:53 AM
dig up te "got boost..." thread in the racing forum; it is reported there around pages 4-6?
john
Boost - Oil Temperature Gauge Install Diy ScottyBoy First Generation Interior & Ice 12 Nov 14th, 2011 08:53 PM
Boost Gauge MNIMGK First Generation MINI Tuning 7 Sep 29th, 2006 06:54 AM
boost gauge springer First Generation MINI Cooper S 1 Nov 6th, 2004 03:15 PM
Boost Gauge Phil 1 First Generation Interior & Ice 3 Jul 8th, 2003 12:26 PM
boost gauge constantly_y First Generation MINI Cooper S 4 Oct 2nd, 2002 04:22 PM
