| Great numbers! So is it safe to assume then that you made your shifts at 6500 rpm? If so, do you think you would've got better numbers using a higher shift point? |
| From my experiences with shift lights you normaly end up shifting gears about 500rpm's after the shift light lights up. So, I'm guessing he was actually shifting around 7,000rpm. Jason 2002 Dark Silver Cooper S w/ white roof. SOLD |
| its possible to get better numbers from better launches. as for the shift point as LuckyRva pointed out the shifts may have gone past the blinking light but i normaly do it by the tack right as its about to hit the first red mark. This mean first gear will go to 7,000 rpm rest are pretty consistant which the graph (off the g-tech) shows 6,610-6,730 per shift. If you noticed my 0-60 foot marks are relative the same no matter the mod. Its a way i learned to launch making it pretty consitant when doing bracket racing and unless i miss a shift my ets are normaly within .05 each time. 02 MCS DS/W (Totaled November 02 on Fall Folage Run) 03 MCS DS/W (See my MINI Profie for extensive list of mods) |
| The GTech starts turning lights on 500rpm before the shift point to allow for this. 2007 DS/W MCS LSD, sport suspension, Enkei RPM2 wheels 2002 EB/W MCS Sport package, Rogue intake, Borla exhaust, 15% pulley & Madness sway bar |
| Andy Why yes i do plan on going to the Drag strip in June. Last year with my old car i particapated in the IMPORT Nationals event. Stock Eliminator class in which i won. I have to return to Defend my Title =). In that event the car was stock with just about every option except the cold package. After a few test runs we set the car dial in at 15.9 with the outside temp being 90+. Time slips varied from 15.9001 for the semi's to 15.9324. With the exception of two by runs that were at 15.743 and 17.892(for the win)in the mains since the other car broke and couldnt make it. Before going to this event i have the old G-tech and tested the car which said i could pull 15.4's 02 MCS DS/W (Totaled November 02 on Fall Folage Run) 03 MCS DS/W (See my MINI Profie for extensive list of mods) |
| Oh one last thing on the data. you will notice i didnt variy the wieght of the car for the test. even though like the exhaust change and a few other minor things did make the car lighter. Doing this is great for comparisons but doesnt show True HP gains. Granted its only about 30 lbs difference but its still a difference. and like when i change rims and tires which doesnt change the HP but will show faster times and Higher HP numbers. Thought id just add that but it gets nick-picked. Andy on your pressure drop measurements i see where Altamini chimed in about there intake. and i was wondering if you could do just one test at speed with that back hole blocked just out of courisity. 02 MCS DS/W (Totaled November 02 on Fall Folage Run) 03 MCS DS/W (See my MINI Profie for extensive list of mods) |
| pretty impresive numbers on the g-tech.i just ran my car at englishtown raceway park 2.444 60 ft e.t. was 14.68 at 96 m.p.h. I had alot of tire spin so this week i hope to run a 14.4 or better. only time will tell but i think it's possible. I'll keep you posted. mods done to my car are helix 15% pully. magnaflow exhaust, and bmp intake. |
| It's not that bad when compared against an exhaust and take into account how much of a difference the diff should make. The Quailfe is $999 + around 8 hours to install. So your looking at $1500 or so. It's having to machine things to get them to fit that worries me. When my warranty has gone totally bye bye I'd really consider this. Paul |
| GTech/Pro Comp installation | Keith | First Generation Interior & Ice | 3 | Jan 25th, 2006 05:36 PM |
| G-Tech Pro : Curious... | Scourtaud | First Generation Interior & Ice | 9 | Sep 27th, 2005 09:57 AM |
| Pics of black "Pro Race 1" or "Pro Comp"? | Jocke | Wheels, Tyres & Brakes | 12 | Feb 17th, 2004 09:46 PM |
| Anyone tried the new G-Tech Pro COMPITITION? | paulmon | First Generation MINI Tuning | 17 | Nov 20th, 2002 01:11 PM |
