| Max, as I am aware of it, the simple K&N replacement filter is ok whereas the full induction kit is not. The K&N filter is simply a replacement for a degradeable component and hence should be ok. I was told that a full induction kit would invalidate the warranty though. This K&N filter should be fine with regard to warranty: http://new.minispares.com/NewMiniSea...s&ShowIcons=No |
| Well i've removed the top of my air-box and paper filter and bolted on a Pipercross cone filter onto the plastic piping. The Pipercross filter was off my Ford Ka and its neck diameter fitted onto the Mini's air intake pipe perfectly! So i got an induction kit for free!!! sounds wonderful! And my Mini went in for its first oil change (10K miles) a few weeks ago and no-one asked any questions! Hope this helps! PS. The TLC package is good on paper but its a bit of a red herring! 1st service(10,000) - they do jack to your car except change the oil! 1st inspection(25,000) - change oil and do simple checks (not even a spark plug change!!!!!!!) 2nd inspection(40,000) - Change spark plugs!!! Yee-ha!!! About bloody time too! I don't think Spark plugs are supposed to last 40K miles! All this info is in the service book. My local Grease Monkey(AKA friendly mechanic) does eveything they do in their 2nd inspection as part of his routine service!!! The only risk in life is to take no risk! |
| Right, it's about 3 weeks until I get my car, so in that time I'll be shopping around for a new filter. Three follow on questions then are: 1. Will a filter give much more bhp? 2. If so, roughly how much? 3. Which is the best filter to go for (K&N? Pipercross?) Cheers! Chris. Lotus Exige S 240 |
| Do not expect any turbo performance. There will be an increase in induction sound and a change in tone.(When pushed) Try out BMC air filters cheaper and better than Pipercross. MINI, it is a way of life. |
| Confused by this now. In this months Evo they say they got their Hartge S serviced for free cos it has TLC. Surely it should have been voided if its a Hartge. And anyway, why do you lose the TLC for doing anything? You buy it, its not free!! How does a car having a different induction system make it more expensive or time consuming to change the oil?? It doesn't does it? Warranty I can partly understand but not the TLC. Gone August '06![]() Arrrived November '08 |
| Changes to MINI TLC & TLC XL | Scrogg | General Discussion | 61 | Mar 28th, 2009 12:12 PM |
| What does MINI TLC & TLC XL Cover | Solwood | General Discussion | 1 | Oct 10th, 2005 09:22 AM |
| What is TLC? | Kaelaria | General Discussion | 8 | Feb 8th, 2005 05:39 PM |
| TLC... What and how much? | Beester | General Discussion | 1 | Jul 3rd, 2003 09:16 AM |
| Anyone NOT got TLC!? | MiniOnd | General Discussion | 18 | Apr 15th, 2003 07:19 AM |
