Manifold or Remap?? - MINI Cooper Forum
First Generation MINI Tuning
 1Likes
  • 1 Post By Cooper R
post #1 of 3 (permalink) Old Feb 12th, 2017, 08:35 AM Thread Starter
Local Time: 05:31 PM
Quoted: 4 Post(s)
Garage
Manifold or Remap??
i have just has my playmini exhuast fitted, sounds really nice but i want a bit more power out the car. Would buying a janspeed manifold be a better idea then a bluefin remap? both around the same price, which would give me more power and overall be better for the car?
thanks
SamRyanR50 is offline
post #2 of 3 (permalink) Old Feb 12th, 2017, 09:17 AM
Moderator
minione2002's Avatar
Quoted: 479 Post(s)
thanks
Bluefin gets my vote
minione2002 is offline
post #3 of 3 (permalink) Old Mar 13th, 2017, 03:13 PM
Cooper R's Avatar
Quoted: 30 Post(s)
Male
thanks
It all depends on how much money you want to spend. From the mechanical engineering point of view, you should bring as much air and fuel as possible but also easier passage of exhaust gases out. So the sound of 4 cylinder engine to be fair if is not reving at 14000 rpm's is terrible. If you want power cheap then exchange manifold but the inside channels should be smooth and also do a ceramic coatingon of manifold on the outside to reduce thermodynamic losses (about 20 'C less loss in kW you will get around 2-4 kW). And than do a custom re-mapping on your hardware (injectors, intercoolers, turbo or compressor and exhaust) that is installed. Then you'll get the best ratio of invested and obtained.
nanotech likes this.
Cooper R is offline
taking a peek through the intake manifold! genik Second Generation MINI Tuning 1 Jul 4th, 2015 11:54 AM
R53 cs New manifold and exhaust problems? Reject86 General Discussion 1 Mar 22nd, 2015 03:50 PM
Can anyone help? R53 The manifold is getting red hot andrejv First Generation MINI Cooper 0 Nov 18th, 2014 06:05 AM
Stock MCS + remap, or JCW stage 1 kit + remap? domystevens Second Generation MINI Tuning 1 Feb 12th, 2014 11:25 AM
New and need some local knowledge for remap around Peterborough Cooper S R56 cheese66 Second Generation MINI Cooper S 1 Jan 14th, 2013 04:21 PM
