| I used something similar in my Spitfire and it made a big difference - smoothed the engine out, revved marginally freer and quietened it down when cold. But that was a 1975 engine (building on late 50s-60s technology). I've toyed with putting some in my Cooper, but certainly at the mo, I don't feel the need. The engine is nice and loose / quiet anyway. It may be psychological advantage on a modern car, didn't seem to do much to my girlfriend's Clio, but maybe made it marginally quieter. It certainly didn't do it any harm. Bottom line - try it, see if you like it. If you see no difference, then maybe you're wasting your money so give it up. Once won't hurt. Just my two penn'orth. |
| Not sure abpout in a modern engine but I had Slick 50 in a Passat Diesel (220,000 miles, no oil used), Peugeot 309 (180,000) and a BWM 325 TD (140,000). I think it can reduce wear and give a longer life but you need to really run the engine in (say 40,000) before you add it and then do it hot. Not sure how it reacts with synthetic either. ![]() WhatCar? Claim: “As hot hatches go, it’s hotter than a blacksmith’s armpit.” |
| [ Bottom line - try it, see if you like it. If you see no difference, then maybe you're wasting your money so give it up. Once won't hurt. Just my two penn'orth.[/quote] _______________ Bottom line: DON"T use Slick 50. Not with a modern engine with fully synthetic oil. |
| _______________ Bottom line: DON"T use Slick 50. Not with a modern engine with fully synthetic oil.[/quote] Once won't hurt but it will not make any perceptual difference. You have to use them over extended periods to 'know' what good or evil they do. these kinds of additives are potentially valuable with older/high milage engines. I think you should stick with synthetic maybe consider Mobil 1 or RedLine if you feel the Castrol is not good enough. I would guess htat a change would negatively impact your warrenty of you had engine trouble so might not be worth the risk. aka KWKSLVR Member: Southern Ontario MINI Club BMW Club of Canada - Trillium Chapter |
| Bad idea - the Castrol synthetic is all you need. If you're not comfortable going the full service interval, then change every 5,000 miles (the oil is still clear at that point, giving you an idea of how well the MINI engine is sealed). Chip H. ex-MINI Cooper S owner and all around good-guy |
| The stuff we use as OE is the best there is, Slick 50 won't do any damage as such but the syth Castrol is used in BMW 'M' as standard and its the same spec, you'd be better off by keeping it on spec. |
| zMax additives | CurtP | Maintenance & MINI Care | 4 | Nov 10th, 2010 01:44 PM |
| Oil type and slick 50 | crimprof | General Discussion | 3 | Aug 17th, 2005 01:36 PM |
| do i need to change oil filter when changing engine oil? | asinn | Maintenance & MINI Care | 6 | Jan 27th, 2005 04:20 PM |
| Oil Additive For New Cooper Engine Not Slick 50 but Slick 50 Synthetic? | scott321172 | Maintenance & MINI Care | 8 | Feb 13th, 2003 08:52 AM |
| changed my engine oil and oil filter today :D | erichui | Maintenance & MINI Care | 15 | Dec 23rd, 2002 08:56 AM |
