| That might be hard to get in this thread as many JCW guys might not be reading this... Maybe I'm wrong. I like the approach though! I organized a pulley party here in NorCal and at that time Randy noticed oil on the underside of my engine, prior to the install. It made me sick when he said that I should go to my dealer asap... as I'm getting a warranty-voiding mod installed at that very moment But, I knew, and several folks standing around my MCS (witnesses ), that the reduced pulley was not obviously the cause...I let my dealership know via a phone the next day, with a follow-up email, with photo attached to show the oil drip points. I also made clear point blank about the pulley, and how & when this was discovered. An appointment was set-up, and they verified that it was the valve cover gasket. The part got ordered, and installed the following week... I've put my MCS up on the ramps a few times since, and no oil! Previously, wipping her clean would expose a drop or so the next day... I realize that not all dealerships are the same, but I would be upfront about it. If my mods cause issues, I take full responsibility and I wouldn't want otherwise. And, if its the other way around, I will hold them to task... I'm still a little upset about the crack in my windhshield that will not be covered b/c of a chip mark. Yes, I'm aware of the many threads... Oh well, best of luck, and hope someone can get Max that JCW pulley figure... '03 (9.6.02) MCS IB/W Lapis Blue Leather Mission = 10:1 (Weight:HP) |
| QUOTE=TonyB] I'm still a little upset about the crack in my windhshield that will not be covered b/c of a chip mark. Yes, I'm aware of the many threads... QUOTE] Thats what 0 deductible glass coverage on your insurance policy is for ... mine costs me a grand total of 6 dollars a year extra and does NOT raise my premiums if I need new glass (have had 6 windsheilds and a side window replaced in the last 14 years) |
| from itzamazin: " I trust Randy's knowledge without question. ... I don't know if it makes any difference to anyone or not, but I found it both interesting and bothersome at the same time. ... After reading Randy's information that the "standard" 15% Pulley is 2.17 inches and the "JCW Pulley" is 2.21 inches." for the record: the stock pulley I measured at 2.586" diameter (65.6mm) (from Liam: "max the std pulley is in imperial but a metric equiv is 66.6 mm BTW its the top of the Vee".. the measure must have suffered a Lorentz transformation travelling at internet speeds.) the 15% P&D pulley measures 2.200" dia, exactly 15% reduction. OD is measured from vee tip to vee tip in the area where the belt rides. I have not measured any other pulleys, but If the JCW pulley measures 2.210", that is a 14.6% reduction. john |
| ahh I shall have to get my mic out then I was just refering from a proudction drawing and the wrap circumference is 130.3 mm so I'll work out what wrap we are gonna get with 15% smaller pulley. ahhh hang on just a thought. prehaps us brits couldn't handle the power from a 1mm smaller pulley like the yanks can hahahahahahahaha its all about the GG (or in this case the uhhh SCREW) Last edited by Liam"S"; Aug 19th, 2003 at 11:37 AM. |
| I stand corrected, John is correct. It appears that the drawing took the measurment from the belt guide and not the top of the vee. so the actuall size is 65.6mm hehehehehehehe. Never trust a drawing hey its all about the GG (or in this case the uhhh SCREW) |
| FYI. Measured the stock pulley OD at 2.585 and the JCW pulley OD at 2.285. Therefore, the JCW pulley is 11.6% reduction, ((2.585 - 2.285) / 2.585 * 100). Airedale MCS '03 BRG w/All Packages plus H-K. DOB~1/17/03. |
| pulley reduction | zippyy | First Generation MINI Tuning | 7 | Nov 27th, 2006 11:47 PM |
| 19% Reduction Pulley ? Are they safe ? | Perm | First Generation MINI Tuning | 3 | Mar 21st, 2006 08:28 AM |
| 15% reduction pulley | ScottishcooperS | First Generation MINI Tuning | 27 | Dec 7th, 2005 07:25 AM |
| 15% reduction pulley | Idontbrakeforcorners | First Generation MINI Tuning | 13 | Dec 23rd, 2004 12:09 AM |
