GTech Pro Meter in Cooper S - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Oct 23rd, 2003, 12:19 AM
Sonic Cooper's Avatar
Local Time: 02:58 AM
Australia
Hi,
I'm having problems getting the GTech Meter Pro running off the cigarette lighter plug in
the Cooper S. Has anyone used a GTech meter in their Mini ? What could be the problem ?
It seems to fit into the plug and contact well. The meter is working aok in other cars.
Thank you.
Shaz.
Old Oct 23rd, 2003, 04:15 AM
CanberraCooperS's Avatar
Gone Old School
Australia Male
I had this problem when i put a shift light on the car... Found that the socket it self was not working properly with a standardised plug on the Shift light... I also tried a mates Standard G-Tech and it had the same problem... I had the cigarette ligher replaced.. all ok now.
Worth having it looked at.. it seems to me though when you look at the Ciggarette lighter socket that its different to the normal.. but it could just be me seeing things
Old Oct 23rd, 2003, 04:38 AM
motoring's Avatar
Autox Monster
Local Time: 08:58 AM
United States View motoring's Indi Blue & White 1st Gen MINI Cooper Profile
ThePilo on MCO found that the cig outlet has conditioned power, ie no alternator interference. He sells a little adapter for hooking up a Gtech.
I have no connection with Pilo and I have not purchased the adapter so I have no other info.
IB/W MC with the really big checkered flag on top
2004 H Stock National Champion
Old Oct 23rd, 2003, 12:47 PM
Mugami's Avatar
Local Time: 11:58 AM
United States View Mugami's Dark Silver & White 1st Gen MINI Cooper S Profile
strange motoring .. im using the G-tech in mine with no problems off the standard socket. but as canberra suggested. if its a case of the G-tech might not be comming on at all then its due to the half depth sizeof the standard lighter plug in the mini and a new one may be needed
02 MCS DS/W (Totaled November 02 on Fall Folage Run)
03 MCS DS/W (See my MINI Profie for extensive list of mods)
Old Oct 23rd, 2003, 06:44 PM
Local Time: 04:58 PM
Netherlands View JBOO's Solid Black & White 1st Gen MINI Cooper S Profile
I just received mine today and was a little worried after reading this post. Lucky for me I hooked it up and it appears to be working properly. Is yours not working at all or just not giving accurate information?
Digi-Tec MCS Gone
Life without a supercharger is boring
Old Oct 24th, 2003, 11:49 AM
jlm
Local Time: 10:58 AM
my present G-tech works fine, although my first unit had to be sent back and exchanged. try it out in another vehicle to be sure.
john
Old Oct 24th, 2003, 08:05 PM
For those of you that have your G-Tech working properly, what type of results are you getting for HP, 0-60, 1/4 mile, etc...........
I haven't had mine long enough to get anything consisent, so was just wondering what
you're getting. Maybe I should start a poll
Digi-Tec MCS Gone
Old Oct 24th, 2003, 08:10 PM
6X therapist
View Goonery's Classified Ads
MINI and BMW cigar lighter sockets often do not work well with non original (BMW) plugs, best thing to do is buy an aftermarket socket and try that. If you buy an approved BMW spare or accessory with Cig Lighter plug it works ok, but others from general auto shops often don't.
Old Oct 24th, 2003, 08:11 PM
Local Time: 03:58 PM
There are some cars that seems to be able to run it, and other that do not. I am not sure why it works on some but does not for others. I do have a harness that will allow it to work in those that do not work. It also helps in making a Stealth install, as well as turning on and off with the car so that you don't need to unplug it every time you get out of the car as if it was hard wired in to the car.
E-mail me @ mini@thepilo.com if you have more questions
Dan
Pilo Racing www.piloracing.com Intakes, Ignitions, Heads, Superchargers and more... stop on in
Old Oct 25th, 2003, 02:39 AM
Australia
Australia
Hi All,
Thanks to all for your input. I suspect at this point the cigarette lighter socket is faulty, will be taking the G-Tech Meter & 'Sonic' Cooper to Mini this week for a health check.
Cheers, Shaz
Old Jan 1st, 2004, 09:42 PM
sergio rollerfunk's Avatar
Spain View sergio rollerfunk's Chili Red & White 1st Gen MINI Cooper S Profile
JBOO,
We seem to have exactly the same mods on our MCS (Digi-Tec + Mini Mania intake...around 220hp). What kind of results/numbers are you getting from your G-Tech Pro? (HP...torque...0 to 60/100...)
I just ordered a G-Tech Pro Comp, and I can't wait to see how's my car doing on the paper.
Thanks.
Chili Red/W/W MCS.
05 Mitsubishi Evolution VIII >>> 12.08@114.8mph
Old Jan 2nd, 2004, 07:57 AM
Quote: Originally Posted by sergio rollerfunk
JBOO,
Thanks.
Sergio-
Welcome back. Good to see you and your S made it to the US and I hope safely. I haven't played around with my GTech much since purchasing, however, I've been able to get consistent 0-100 k.m times of 6.6-6.8 seconds when I tried. If the weather permits, I'll try to start getting some more times down to compare with you.
Digi-Tec MCS Gone
Old Jan 2nd, 2004, 08:02 AM
Oh, BTW, now that you're in Colorado, you should go check out the Milltek exhaust that Randy of Webbmotorsport carries. I've been thinking of buying it to release some more of that DT power.
Digi-Tec MCS Gone
Old Jan 2nd, 2004, 01:12 PM
JBOO,
It'll be great to compare numbers once I start playing with the new toy!
But one thing I can tell you though...your S should be by now waaaaaay faster than mine ...why? altitude! My poor MINI has an everyday battle with elevation...6,500 feet (2,000 mts) is no joke. It feels like when it was stock, just adequate, but not fast, even with the extreme cold temperatures we get over here. The air is so thin...you can hardly breath.
I haven't put the intake yet, because I will like to see some numbers before and after, but I'm not expecting miracles. About the Milltek exhaust, it seems like a great option. That will be my next step, but I haven't decide yet. I was tempted with the Magnaflow, but I hear everywhere that the thing is sooooo loud...But anyways, It's a good thing there's a MINI tuner here in Colorado. (Webb)
Question: Do you know the drag Cd and the frontal area for the MCS? I know that the G-Tech needs that info in order to provide some measurements. I believe that the S has a 0.37 drag coeficient (very poor) but I'm not sure.
Nice talking to you again!
(We'll keep in touch....)
Sergio
Chili Red/W/W MCS.
  #15 (permalink)
Old Jan 2nd, 2004, 01:21 PM
BTW...In my way back from St. Louis, MO, (right after picking up my car), my windshield got busted by a rock thrown by a eighteen wheeler while driving through Kansas...
...another MINI with a cracked windshield...and counting.
Instead of fixing it, I replaced it...I couldn't live with a 5 inch crack right in front of me...
Chili Red/W/W MCS.
pro mini induction kit (COOPER) Haggi First Generation MINI Tuning 2 Sep 15th, 2006 07:52 PM
GTech/Pro Comp installation Keith First Generation Interior & Ice 3 Jan 25th, 2006 05:36 PM
GTECH Competition Pro Accuracy apexi First Generation MINI Tuning 13 Sep 23rd, 2003 02:12 PM
GTech/Pro Competition Keith First Generation MINI Tuning 21 Feb 6th, 2003 09:56 AM
Gtech/Pro Competition in the UK? Paul First Generation MINI Tuning 2 Jan 22nd, 2003 07:10 AM
