Exhuast Tip Help Sought (2.5" Flat/Oval Shape) - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Feb 7th, 2004, 02:46 AM
TonyB's Avatar
Don MINIo
Local Time: 03:50 PM
United States View TonyB's Indi Blue & White 1st Gen MINI Cooper S Profile
I suppose as a few of you know, I'm in the midst of fabricating an exhaust system (catback) for my MCS. It's coming along quite nicely, and I'm at the stage now to where I need to start purchasing product.
I'm seeking an exhaust tip that very much looks like the one included below. I know that there are some folks who prefer other types, but I really like this ones low profile and how it fills the valence openning. They are unique, and I guess I also find that appealing.
The one below is a 2.25" tip, courtesy of Adel. Mine will need to mate-up with 2.5" muffler outlet though. While I know that this is doable, I'd prefer a 2.5" tip, in this style. If anyone knows of such a tip, PLEASE do share. It would be greatly appreciated.
Thanks.
'03 (9.6.02) MCS IB/W Lapis Blue Leather
Mission = 10:1 (Weight:HP)
Old Feb 7th, 2004, 03:20 AM
Send a message via AIM to macncheese Send a message via Yahoo to macncheese
Local Time: 07:50 PM
United States View macncheese's Dark Silver & White 1st Gen MINI Cooper S Profile
Tony,
The solution is easy. You can get a oval outlet Spintech, as well as oval tubing/tips from Spintech. They make oval tubing for extreme clearance situations/street rods. Good luck!
Cheese
Old Feb 7th, 2004, 03:55 AM
TonyB's Avatar
Don MINIo
Quote: Originally Posted by macncheese
Tony,
Cheese
mac, upon first reading your post, the oval inlet/outlet Spintech muffler came to mind. That would not work with my application as I'll be inverting the muffler, so the oval would be going vertically, not horizontally to match the valence shape...
I then decided to visit the Spintech site again, and they actually have tips that go from round to oval! Good job. But, I see 2 things of concern... The lengths are like 18". One is said to be "short," but no length is provided. And the width of the oval is either 3.5" (the short one), or 4". I believe the one that fills the valence in the intial post is like 6"...
Of most concern though is the length of these tips. With only like 20 or so inches (a bit more I believe) to work with, muffler and tips need to fit...
Here is a link to their tips:
http://www.spintechmufflers.com/spin...ntechindex.asp It appears that I can't link to it directly. Oh, well, accessories, then tips, I believe...
I'm attaching a couple photos of what a few look like.
I can call them on their short one, to see just how short it is...
ID:	29769   Click image for larger version
Old Feb 7th, 2004, 04:06 AM
Tony,
You dont want a tip, you want a "transition". They're a lot shorter... then you just need to bust out the Wenol and get polishing.
or try these vette tips... they're 3" tho.
http://mechamperformance.com/d_docs/e_tips.html
Old Feb 7th, 2004, 05:34 AM
TonyB's Avatar
Don MINIo
Thanks mac, I saw the transitions, but didn't realize that I could work one into a luster . I've been scouring the web for almost an hour, and found nothing, well, minus a possiblity in Australia. I might need to make the 2.25" one work... I saw those Vet ones. Nice. Oh well...
Old Feb 7th, 2004, 11:44 AM
jlm
Local Time: 06:50 PM
it's pretty easy to squeeze one end of a round tube into an oval,. I use flat dies on a press brake and plug the tube temporarily with a compressable urethane to prevent butt cheeks from forming. You could probably get there using a vise or a frame press.
john
Old Feb 7th, 2004, 05:07 PM
norm03s's Avatar
United States View norm03s's Dark Silver & Black 1st Gen MINI Cooper S Profile
More detailed pic of Oval tip
Thanks.
Yes it is a 2.25" inlet but that could be cut out and a 2.5" transistion welded in. So then it would be a slip on. There appears to be enought height to make this mod from this pic's angle.
T815 - The T815 is a polished stainless steel tip 8 ½inches long and 6 inches in diameter and has an oval cut finish. The inlet diameter is 2 ¼ inches wide. This tip is manufactured with high quality T-304 stainless steel.
http://www.toucanindustries.com/clie...ducts/T815.jpg
Wish I could get this picture posting thing down pat......Drats, HELP!
"I have no data yet. It is a capital mistake to theorize before one has data. Insensibly one begins to twist facts to suit theories instead of theories to suit facts."
- Sir Arthur Conan Doyle
Old Feb 7th, 2004, 06:23 PM
TonyB's Avatar
Don MINIo
I'm going to post that picture below. To do so, one cannot use the Quick Reply feature (in case you are). So, do a Reply, and then you should look for Manage Attachments. This willl allow you to upload 1-3 items. Before doing any of this, you do need to download what you want though. With this one here, I went to your link, right-clicked on the image, and saved it to my desktop. If this is too much detail, I apologize....
John, thanks for your input! I'm feeling better about making this tip work. I'm just going to order this tip, and post some different shots of it to get some possibilities on maybe the best way to convert it... Of course using some intermeditate piece to bring the two together (tip inlet & muffler outlet) is going to lengthen matters, at least minimally. This is going to then impact what I should do further-up...
Thanks!
Going under my MCS now to do some more surveying, and snap a couple shots.
When will current shape devalue with release of new shape? sam_pd General Discussion 9 Aug 1st, 2006 01:51 PM
Exhuast tip sizes? Drifter First Generation MINI Tuning 4 Jul 26th, 2005 04:20 PM
Oval tip exhaust performance elmejorrematador First Generation MINI Tuning 2 Mar 4th, 2004 05:33 AM
