Twin Charged MINI. That's a Super and Turbo charger. - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Feb 12th, 2004, 12:21 PM
Root Ginger's Avatar
Amiga 500 to PS3 20 Years
Local Time: 05:02 PM
Saw this on NAM and thought wow!!!
250BHP running stock Pulley and ECU!
http://www.northamericanmotoring.com...22805&start=25
It was acceptable in the 80's
Old Feb 12th, 2004, 12:34 PM
Local Time: 04:02 PM
United Kingdom View PW51CAR's Cosmos Black & Body Color 1st Gen MINI Cooper Profile
Commonly known as a superturbo
Thats a nice looking conversion, very neat.
Would be nice, assuming they are running the charger from low to mid revs then having a cut off and bringing the turbo in at higher revs. Nice way to cut out lag, expensive, but nice
Old Feb 12th, 2004, 12:53 PM
Send a message via AIM to macncheese Send a message via Yahoo to macncheese
Local Time: 12:02 PM
United States View macncheese's Dark Silver & White 1st Gen MINI Cooper S Profile
Stock ECU but its running APEXI S-AFC for fueling and timing.
Cheese
Old Feb 12th, 2004, 01:04 PM
Shorty's Avatar
Send a message via Yahoo to Shorty
England View Shorty's Solid Black & Black 1st Gen MINI Cooper S Convertible Profile
Does it affect TLC?
Old Feb 12th, 2004, 01:20 PM
Cheese
Oh yeah forgot to mention that
Old Feb 12th, 2004, 01:21 PM
Quote: Originally Posted by Shorty
Does it affect TLC?
...and the award for the stupidest question goes to...
Old Feb 12th, 2004, 02:39 PM
TonyB's Avatar
Don MINIo
Local Time: 08:02 AM
United States View TonyB's Indi Blue & White 1st Gen MINI Cooper S Profile
I read that late last night, and I seem to recall that it was 250hp at the wheels, not the crank. Actually, I'm fairly certain as I remember he got a stock reading of 147 or so...
For those who wish to translate that, using 12% as an average loss, that's like 285 hp. Again, that is based upon that 250 figure being at the weels. Very impressive. Let's see what unfolds here. With heat soak being an issue for our MINIs, I'm curious to see the increase of underhood temps with the addtion of a turbo, albeit not a huge one...
'03 (9.6.02) MCS IB/W Lapis Blue Leather
Mission = 10:1 (Weight:HP)
Old Feb 12th, 2004, 02:55 PM
Good point there TonyB another point I forgot to mention
Old Feb 13th, 2004, 08:51 AM
Local Time: 06:02 PM
Greece
VERY interesting work. I honestly wasn’t expecting that. This solution won’t mess with the drivability of the car. The HP gains are gooood, we only need to know if the car maintains a decent amount of reliability and of course how much they will sell it in Europe, if they plan doing so.
Old Feb 13th, 2004, 10:30 AM
jlm
Local Time: 11:02 AM
the output of the turbo is blasted into the supercharger and then into the intercooler. No way would a supercharger cutout work. Should be a good test of the ability of the blower to stand heat, touted by some as a potential shortcoming when running smaller pulleys
john
Old Feb 13th, 2004, 11:23 AM
obehave's Avatar
Mini Mod
Fireworks are fun!!
Old Feb 17th, 2004, 06:55 PM
Greece
Thumbs up
has anyone else kept reading the guys at SPI estimate a cost of 5800$ for the kit???
is it just me or it sounds pretty good.
Old Feb 18th, 2004, 02:35 AM
TonyB's Avatar
Don MINIo
I suppose for the price, and that kind of hp, I believe many will see that as a good deal alright. I'm not crazy about the path, or routing of this system through the SC, as jlm notes above. With those increased temps, and at 20 lbs of boost driving it...
While not available now, I'd still prefer a much more efficient SC that delivers some serious low end, with much less boost. Output also would be in the 275-300 range, as I understand it.
SPI does have me very interested though! I'm going to sit tight to see what unfolds with their twincharger, as well as new developments this year...
Old Feb 18th, 2004, 07:14 AM
Greece
The thermal loads surely must've sky rocked, but as I said they need to prove their reliability and maybe use some thermal coating tape on their manifold. The cost is very attractive and that, probably, because the motor has been opened.
I believe M7 is working on a high end SC for around 300hp, isn’t so?
  #15 (permalink)
Old Feb 18th, 2004, 12:28 PM
Charger_Pete's Avatar
Mini 2 Slap Head
Send a message via ICQ to Charger_Pete Send a message via AIM to Charger_Pete Send a message via MSN to Charger_Pete
United Kingdom View Charger_Pete's Electric Blue & White 1st Gen MINI Cooper S Profile
Ahem, reality check peeps.
There is no way that the turbo outlet would be routed into the supercharger and then through the intercooler. If we pick some basic numbers here we will see why:
Air in to turbo 20degC>>>>>Air out of turbo 120degC>>>>>>into S/C at 120degC and out at 200degC maybe>>>into intercooler.
At this point the supercharger would probably melt its seals and rotors would begin to break down after a while. The intercooler fins and core would simple melt and if the air made it into the engine the combustion system would simple suffer from immence pre-detonation. If the pistons could stand up to it however, you would have to run it on ethanol to achieve any useable combustion.
The logical progression for this setup is to use the supercharger to boost the engine until about 3000 rev/min. At this point the supercharger can be clutched (using clutch pulley) and then let the turbo take over for mid-range and hight speed performance. The turbo would be far more efficient at higher engine speeds.
Dont get me wrong, i am not knocking the installation, it has taken someone a lot of time, money and thought so respect for that! I would be most interested in finding out how this installation really worked.
Pete
Stickin to Cooper S super charged neilobe First Generation MINI Cooper S 29 Dec 23rd, 2006 05:28 PM
Video. Turbo Charged S usaminicooper First Generation MINI Tuning 22 Apr 1st, 2005 04:45 PM
Turbo Charged Mini Cooper + ONE = 240Bhp!!! cfranklin First Generation MINI Tuning 32 May 21st, 2004 01:16 PM
WOW!! super charger & turbo in one kenny78 First Generation MINI Tuning 2 Feb 17th, 2004 07:05 PM
