| Lwt Flywheel & Lwt Crank Pulley ?'s My friend told me that getting a lightweight Crank pulley yields a similar affect as getting a lightweight flywheel, but at a substantial cost difference. He also said that it is supposedly bad to have BOTH the lightweight crank pulley AND lightweight flywheel due to harmonic vibration issues. Is this true? If that is true, which upgrade is the best way to go? Anyone installed a lightweight Crank pulley yet? The crank pulley i am talking about is from MiniMania |
| Don't do it. Lightweight crank pulleys serve the primary function of trashing your engine and belt driven equipment. The stock pulley has a rubber insulator between the hub and pulley, and this damping is necessary for smoothing out normal rpm variations. An engine revolution is a series of accelerations and deccelerations, and without damping the belts are jerked around. The harmonic vibrations of the engine will need that damping especially with a light weight flywheel. If a fluid damper becomes available it might be a good way to go, but the solid pulleys spell death to a 4 banger. Cooper S Red/White/White, Air, Computer, Cloth, DSC, Cold Weather. August build. |
| 19% + 3% crank pulley | james l | First Generation MINI Tuning | 31 | May 24th, 2007 05:58 PM |
| 17% S/C Pulley + 2% Crank | futureal33 | First Generation MINI Tuning | 6 | Feb 8th, 2007 09:23 PM |
| 05 Crank pulley different to O3? | Drewski | First Generation MINI Tuning | 3 | Sep 10th, 2006 09:32 PM |
| 2% crank pulley ?? | brady | First Generation MINI Tuning | 10 | Dec 3rd, 2005 05:37 PM |
| Cooper S Crank Pulley | gt40guy | First Generation MINI Cooper S | 0 | Jan 17th, 2004 10:43 AM |
