| I would agree, get an S. You have to worry about reliability, servicing and the fact you have no warranty left.. But if your racing then the idea is fine. You will need a specialist to come up with a kit though as a one off will cost you upwards of £5k. Jenvey sell TB kits for about a grand for popular engines..then you get the ECU etc. Thing is, doubt the Chrylser engine is good, unlike a Vauxhall 1.6 where you can get about 240bhp from TBs and headwork! I think TB's would fit, just not huge trumpet perhaps, remember some of the engine is removed to put them in in the first place. -Rob |
| Max power? Mock power more like!! this wouldn't achieve 175bhp. with a K-series, adding a bigger body gives about 10-14bhp. you have to remap the engine, change casings, inlets and exhaust as well just to get a slight increase in power. so say, 125-130 bhp for inlet and exhaust then bigger body so about 140 is your lot a set of bodies wouldn't fit in a mini, i reckon. even if they did, you'd need huge inlet valves, bigger exhaust valves, a remap, new fuel pump, fuel regulator, bigger coils etc to get enough spark, and new cams. and you still only get about 180bhp if you were lucky. and that little lot would cost about £4500 to £5000 including set up time. and you'd get about 10mpg. or, as said earlier, you could buy an S. or keep the cooper AND build a westfield for the same amount of money! TVR Tuscan S. 400bhp, 0-60 3.8 0-100 8.08. 195mph. Silver/Black roof Cooper. Hillclimb MK2 Fiesta. 150bhp. Beats Subarus. Building a 'bike engine single seater. 320kg, 200bhp. around 600bhp per ton. 0-100 6 seconds. |
| Okay, okay... I'll get an S... Maybe that's the easiest!!! And tuscan_thunder > I'll stop reading Max Power MC, Milltek (manifold, hi-flow cat, cat back), OneClick, K&N air filter, 17' Alessio Vittoria, H&R lowered 30mm, H&R front and rear swaybars, Blaupunkt MP3/CD, MTX Amp, Alpine 10' Sub. |
| 175 bhp (or more) on throttle bodies is not at all unrealistic - they do fit, but the engine needs completely remapping - not an off the shelf software upgrade - mapping for the actual car on a rolling road. Have you seen the route the tiny tuned length inlets take on the MINI and how much simpler and more direct a TB setup is? Its a much purer setup. They get great results on many cars. |
| throttle body | marcy | First Generation MINI Tuning | 12 | Mar 1st, 2007 10:26 PM |
| Throttle Body upgrade. | jeremyseda | First Generation MINI Tuning | 4 | Oct 6th, 2005 01:37 AM |
| M7 Throttle body | jonnyc | First Generation MINI Tuning | 17 | Jun 27th, 2005 10:09 AM |
| Throttle body. | GTT 280 | First Generation MINI Tuning | 1 | Feb 2nd, 2005 03:22 PM |
| Which Throttle Body to Get???? | Redleg13 | First Generation MINI Tuning | 15 | Jul 21st, 2003 03:06 PM |
