Boost Gauge Install: OEM Vacuum Line - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Sep 17th, 2004, 10:29 PM
Amigo's Avatar
Local Time: 03:05 AM
Hi All,
I am considering installing an electric Boost gauge which requires a T-Piece to be spliced into the OEM vacuum tube. Not having removed the intercooler myself, I was wondering:
1. Is it difficult to remove/replace the intercooler?
2. How would I identify the vacuum tube which needs to be spliced?
3. Would I need to install clamps on all ends of the T-piece?
Appreciate your insight and advice.
Regards,
Eddie
Who's on First....
Old Oct 21st, 2004, 05:28 PM
Local Time: 04:05 PM
Netherlands
Hi,
I wanna do the same thing. Did you already install it?
Please let me know how you did it.
Old Oct 21st, 2004, 09:58 PM
Amigo's Avatar
Quote: Originally Posted by CaMeroN
Hi,
Hi CaMeroN,
Yes, I did manage to install it. Initially I thought I would have to tap either the primary or secondary IC manifolds as some have done, but fortunately I came across a recommendation from jlm which required only a T piece installation from an OEM line.
Follow this link and look for jlm's detailed post:
http://www.mini2.com/forum/showthrea...0&pagenumber=2
Good luck with it
This link shows my final installation:
http://www.mini2.com/forum/showthrea...hlight=finally
Who's on First....
Old Oct 23rd, 2004, 04:43 PM
Netherlands
Thanks Amigo.
What is the best way to get from the egine compartment to the inside of the car? Are there any existing holes I can use?
And what about lightning? Which wires are you using for your guages?
Your setup looks great by the way. I Hope I'll get mine in soon too.
Old Oct 24th, 2004, 01:24 PM
Amigo's Avatar
Thanks Amigo.
On our right hand drive cars, there is a rubber gromit on the upper left firewall (facing the car). I punctured this to pass through two sender wires (oil temp and pressure) and one nylon tube (for my mechanical boost gauge). I was able to pass the wires and tube through existing holes on the plastic shield in front of the firewall.
As for ignition power for the electrical gauges, I used the power from the cigarette lighter and for the lighting power, I used the illumination power to the stereo head unit. I passed a ground wire from cabin to the engine bay through to the standard ground point near the engine. This wire was passed through another existing rubber gromit on the firewall, as I already had too many going through the other hole.
To have a better idea - reference your gauge wiring instructions or refer to the OEM wiring diagram Mini issued for their own gauges. This should be available on the net or from your dealer.
Who's on First....
Boost - Oil Temperature Gauge Install Diy ScottyBoy First Generation Interior & Ice 12 Nov 14th, 2011 08:53 PM
Boost Gauge Install - Do I Have This Right? Mat-CooperS First Generation MINI Tuning 10 Jun 2nd, 2007 01:28 AM
Boost Gauge Install wrecky First Generation Interior & Ice 1 Sep 12th, 2005 12:20 PM
No vacuum, only boost, right? jmardy First Generation MINI Cooper S 9 Aug 22nd, 2002 08:48 PM
