Installing the reduction pulley - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Sep 18th, 2004, 03:06 AM
onasled's Avatar
Local Time: 11:05 AM
United States View onasled's Classified Ads
Well, I’ve tried to search out this question in both this forum and in North American, but have yet to find what I’m looking for.
Has anyone posted instructions of how to install a reduction pulley on the blower? If not, can someone do so? I’d like to know just what’s involved, detailed somewhat, in doing so before I pay a mechanic.
Old Sep 18th, 2004, 03:26 AM
MINIAC's Avatar
Canned
Local Time: 09:05 AM
From Randy Webb ...
http://www.webbmotorsports.com/forum...topic.php?t=17
Old Sep 18th, 2004, 05:22 AM
CooperSAZ's Avatar
All 4 wheels pointed down
United States View CooperSAZ's Liquid Yellow & Black 1st Gen MINI Cooper S Profile
Holy Moly is that detailed!
That also gave me my final answer as to whether or not I will attempt that! I will stick with furthering my mechanical skills in the art of air intakes and exhaust systems!
Old Sep 18th, 2004, 12:50 PM
onasled's Avatar
,,,, thabks. Not sure I will attempt it. Maybe 20 years ago, but .;......
Old Sep 18th, 2004, 09:20 PM
Bisch's Avatar
Nut Job
It's really not that difficult...just have your tools, a couple hours, and patience.
Hey, it's just nuts and bolts...not brain surgery.
...a beer or two won't hurt either.
Old Sep 20th, 2004, 10:48 PM
Nbusch1128's Avatar
SIZE XS
Local Time: 12:05 PM
United States Female View Nbusch1128's Dark Silver & Black 1st Gen MINI Cooper S Profile
DH just put mine on this last weekend. He is not mechanic, he said that it's straight forward, if you can follow instructions and can turn a wrench, you can handle this. He adds, that Randy Webbs instructions are idiot proof. He rented a puller kit from Promini http://www.promini.com/product-exec/...category_id/28
I say go for it!
Old Sep 22nd, 2004, 10:13 PM
Local Time: 04:05 PM
Anyone know if you should upgrade any other part on your MCS prior to the pulley upgrade.
I've got a stock MCS and if thats my only upgrade am I gonna have issues later > ex. Engine damage, excessive wear, etc.
I noticed on M7 website they recommend they're bigger fuel injectors to avoid engine issues.
This a fact?
-Thanks-
Shenmue
Old Sep 22nd, 2004, 10:21 PM
minimort's Avatar
King of Holden
United States View minimort's Dark Silver & Body Color 1st Gen MINI Cooper S Profile
Pulley Install
I did mine about 2 weeks ago, and it wasn't that bad at all. I did it in the morning before going to work, so taking my time, doing it over a period of 3 mornings, for about 1hr per morning and runs fine now. Followed Randy's directions with the ProMini rental, best way to go to avoid install fees.
Cost, with shipping, about $200, not bad given Randy's install quote is $400, but then again, he is a professional.
Old Sep 22nd, 2004, 10:53 PM
onasled's Avatar
I'm going to do it. Thanks for the input here, I feel better about doing this now. Anyone in the CT area have a pully?
Old Sep 22nd, 2004, 11:08 PM
bodinski's Avatar
[hot rod harlot]
Local Time: 10:05 AM
View bodinski's Indi Blue & Black 1st Gen MINI Cooper S Profile
I did mine last week. During re-assembly, I found an easy way to install the driver's side motor-mount bolt. If you tighten down the pass. side mount nut first (just line it up based on the scratch marks), you'll only have to adjust up & down to insert the driver's bolt. Otherwise, it's pretty tough to get it threaded.
Two other things:
Don't try using ramps instead of stands. I started that way & found the motor wanted to rock back too much as it was lifted. Switching to stands straightened things out.
Allow 5 minutes or more after disconnecting the battery before unplugging the ECU. According to the new Bentley manual, it and certain other components can retain power awhile after the battery is unhooked.
Have fun, but don't get caught!
Bodinski
Old Sep 30th, 2004, 11:34 PM
onasled's Avatar
OK, I did it. Was really not hard at all. I think I spent more time hunting down my tools when misplaced or when they fell down in the engine compartment then I think I did replacing the pulley. But really, it was a bit unnerving lifting the engine on my new MCS of only thee weeks, but with Randy’s write-up, it was a snap.
I will recommend that anyone with any wrench experience and a garage or shop floor to do it in should go ahead and do it yourself.
Old Oct 8th, 2004, 04:00 PM
Hey onsled,
Any pointers on how to safely jack the mini on jack stands - been hearing some stories where the jack points are hollow plastic blocks with a retaining pin.
I've got my pulley on order and plan to do it with a friend next weekend, like you I'm nervous about the install, but more nervous about the safety factor now.
did you have any problems jacking up your mini? and how did you do it?
thanks
shenmue
Old Oct 10th, 2004, 06:10 PM
onasled's Avatar
Shenmue
Sorry, I was up in NH this weekend with no internet access.
Jacking was cautious, but being that you are just jacking the front. It’s not much of a problem. Jacking on all fours is a bit tricky as the jack stands want to slide a bit. Once up things were OK. Just tack it real slow.
I'm sure you've already done this being that it's Sunday already. How'ed it go?
Good luck
Old Oct 11th, 2004, 03:33 AM
hey onasled,
No I haven't done the upgrade yet - scheduled soon though. Still waiting on parts, but I did lift my car and noticed that the lift point did slip a little when lifting the opposite side.
I'll definitely take your advice on working on it slooow :P
shenmue
pulley reduction zippyy First Generation MINI Tuning 7 Nov 27th, 2006 11:47 PM
15% reduction pulley ScottishcooperS First Generation MINI Tuning 27 Dec 7th, 2005 07:25 AM
15% reduction pulley Idontbrakeforcorners First Generation MINI Tuning 13 Dec 23rd, 2004 12:09 AM
Need reduction pulley input StevoMC40 First Generation MINI Tuning 16 Oct 9th, 2004 03:57 PM
